Old 03-11-2015, 01:18 PM   #41
Sorry didn't see the question directed at me! The aux (transfer tank) that we have is made by RDS MFG and sold by 3Gtool boxes, $399. 3G Toolboxes
We have 70307 and is strapped in with 2 15K tie down straps for easy in and out. You have to get a diesal install kit for it, depending on trk. Basically what it is a valve with a floating stopper in the aux tank feed line. Theres one 1/2" fuel line that comes up thru bed of truck, 1 clamp. You have to cut a section out of the rubber fill line and install the valve.
Way it works is it gravity feeds into main tank keeping it full, the float shuts aux tank off when main tank is full. When you see your tank gage start to go down you got 26 gallons (Ford) left till its panic time! When we stop for couple days I just make sure to top off the aux tank and we always have 700 +- till empty. This is our 3rd year and I have not, knock on wood, had to get fuel with the 5er attached! Let me know if more info need I mite pics somewhere!
rooksroost is offline   Reply With Quote
Old 03-11-2015, 03:03 PM   #42
Originally Posted by MN John View Post
FYI - I don't know the exact date that i'll be picking up the XLR yet (purchased in Dec. and dealer is storing it), but will likely schedule the pick-up date when I'm there having the hitch installed on 3/24. Taking delivery of the XLR was dependent on the spring weather conditions...but it looking good up here right now. Likely can be de-winterized soon with no concerns of anything freezing solid.
We are doing the same. Ours just landed at the dealer today and with it being 55 out now, I don't imagine I can wait much longer to pick it up....
taken is offline   Reply With Quote
Old 03-16-2015, 07:30 AM   #43
Originally Posted by B and B View Post
Hello John. That is exactly what I would plan on doing. We have two us and one small dog. We really don't need the crew cab. What do they say for Cargo Capacity and Tow Rating with the truck as you equipped it?
Picked up the truck this weekend...payload sticker puts it at 3544 pounds. Will put the truck on the scale once the hitch is installed.
ID:	71431   Click image for larger version
Doreen & John
2015 XLR Thunderbolt 340x12HP
2015 F350 Lariat SC SB 4x4 6.7 SRW
2012 HD Ultra Classic
MN John is offline   Reply With Quote
Old 03-16-2015, 07:54 AM   #44
We are indeed very close then. Mine, which is the identical layout to yours, except for options probably, is 3568#. With the wife, myself, our two year old in her car seat, a full tank of diesel, and the hitch in, came in at 8520# leaving the actual payload for towing/pin weight at 2980#. I'll be curious to see exactly how close we are on actual scaled weight...
That said, I'm sure I've been over mine. The axle and tire ratings are higher than the sticker ratings and the ones I personally keep an eye on.
Old 03-16-2015, 07:57 AM   #45
What is the gvwr of your trucks? My ram is 12400 and I weighed it last week with full tank and myself (265lbs) in it and came across the scales at 8700...which surprised me as it is completely stock except for a roll up tonneau cover
gtsum2 is offline   Reply With Quote
Old 03-16-2015, 08:32 AM   #46
GVWR on ours is 11,500. Ram SRW's have us beat for now...
Old 03-16-2015, 08:42 AM   #47
I guess Ram needs the higher GVWR due to its more portly weight
Old 03-31-2015, 07:32 AM   #48
Originally Posted by gtsum2 View Post
Well congrats on the soon to be new xlr too! Share some pics of the new combo when your em hitched up!
Picked up the new XLR 340x12 HP at the dealer yesterday...currently in the driveway checking it out (so far so good, everything functioning as described), and starting to stock with the basic needs.
Doreen & John
Old 04-02-2015, 07:07 AM   #49
Hi John & Doreen
We also just picked up our new 2015 F250 as our 5th wheel is smaller than yours. I see
that you also got the 5th wheel prep package. In our 2011 I had the Reese after market
under bed kit installed for my Reese Elite 18K hitch. When the hitch was removed and you looked down into the pucks there was bottom inside them. On the factory installed ones you can see right through them to the ground. Just wondering if yours are the same.
Ron
furtrader is offline   Reply With Quote
dealer, f350
