Old 06-03-2015, 08:51 PM   #1
New fifth wheel hitch.
We are getting a short bed truck so we will need the sliding hitch. I was considering a Hensley air ride. Do they make a slide hitch that will work?
Fatty1 is offline   Reply With Quote
Old 06-03-2015, 10:01 PM   #2
bigdaddy1
bigdaddy1's Avatar
I like my super glide hitch for my standard bed F350. It is fully automatic so I do not worry when I am backing into a site or home base. Sharp turns are not a problem as well.
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2016 3850RL Cardinal
bigdaddy1 is offline   Reply With Quote
Old 06-03-2015, 10:51 PM   #3
Does yours have air bags in it? Or is that even an option? If not do you experience "chunking"?
Old 06-03-2015, 11:02 PM   #4
Blog: RVroadtripper.com
hbillsmith's Avatar
What is your trailer and which TV? Have you considered an Andersen Ultimate Aluminum? I have one in a 6.6 ft std bed and its fine. No slider needed.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 06-03-2015, 11:03 PM   #5
Long Leaf Piners's Avatar
We just left our Reese Revolution pinbox and 16K Reese hitch to return to the PullRite 16K Superglide, with the Revolution in the fixed, or transportation, mode; and boy are we happy!
The SuperGlide on universal rails is an amazing hitch that we first came to use in 2008. I would suggest you consider it, carefully.
2014 8528 IKWS
Ford F-250 Diesel
Cricket the Cairn and Sally the Terrier Muppet Mix
Long Leaf Piners is offline   Reply With Quote
Old 06-03-2015, 11:09 PM   #6
By the way, recent talks with 23 year and 14 year hitch installer specialists revealed that airbags (now suggested to never be lower than 5 pounds...or 3 pounds) when jumped on, immediately adjust themselves to 20 pounds. This means that the ride stays stiff at all times. We opted for low tech, but never overridden, extra leaf spring. Works great!
2014 8528 IKWS
Ford F-250 Diesel
Old 06-04-2015, 08:17 AM   #7
bigdaddy1
bigdaddy1's Avatar
No Fatty1 my truck is F350 I do not need airbags with my fifth and I have no chunking sounds at this point.
BigDaddy1
6.7 diesel
Old 06-04-2015, 08:52 AM   #8
Simple solution, air pin box and then pick the slider hitch you think is the best for you. After 10 years I am still using the same non slider hitch that I originally bought. It still works just fine. With an adjustable jaw, I can take any slop out of the head in two minutes. I just do not see enough difference in hitches to justify the money on a new one.
donniedu is online now   Reply With Quote
Old 06-04-2015, 12:55 PM   #9
I love my BD3. After breaking some front windows on a previous fifth wheel while driving on one of our concrete railroads, aka I-65 South from Louisville, I decided the cost would be worth it. I have the short bed but have never been in a place where I needed to use a slide.
Duke is offline   Reply With Quote
Old 06-04-2015, 12:58 PM   #10
Claude002's Avatar
I have a 4 door Toyota Tundra with Firestone Air Bags pulling a Crusader 290 RLT With a Husky Adjustable EZ Roller ---Changed the Hitch for a Reese Airborne---the difference is night and day ---Air bags do make a big difference.
Claude002 is offline   Reply With Quote
fifth wheel, hitch, wheel
