Old 04-22-2011, 09:44 AM   #11
Glenn5995's Avatar
If the fifth wheel is currently level, by adjusting the pinbox up the fifth wheel will now be high in the front. This will shift the trailer load to the rear axle and potentially overload the rear axle/tires. It will also give you less clearance at the tailgate which is where I usually have problems.
If your fifth wheel is currently a little low in the front when hooked to your tow vehicle, then you could raise the pinbox up a little to level out the fifth wheel and gain a little clearance.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 04-22-2011, 09:50 AM   #12
would putting on the 3" lift kit on my pullrite hitch do the same thing? or is that a better option to get clearance?
jalvin is offline   Reply With Quote
Old 04-22-2011, 09:55 AM   #13
Herk7769's Avatar
I also have had to lower the tail gate and take a different line on uneven ground due to clearance (once and will never visit KOA K......t again for that reason) to avoid contact.
If this does happen to you can get a 3 inch lift kit for your Pullrite relatively cheap.
http://www.pullrite.com/pdfs/4408.pdf
You might also need to lift the frame of your camper to avoid an out of level tow. (This is VERY bad since it shifts weight that should rest on all four wheels aft onto the rear wheels. Additionally, it also increases drag due to increased area in contact with the relative wind and your fuel mileage will go further south than it already is.) Not a job for the faint of heart, either.
HAM CALLSIGN - KC3FFW
Old 04-22-2011, 10:02 AM   #14
Glenn5995's Avatar
The lift kit for the hitch will just do the same thing as adjusting the pinbox up.
Try it the way it is first, if you have problems, then you need to lift the trailer (there are several options depending on what type of suspension your trailer has) and then adjust the pinbox and/or add the lift kit to level the fifth wheel.
Old 04-22-2011, 10:12 AM   #15
Herk7769's Avatar
Oh, one more thing.
The instructions for the lift kit show it being bolted to the cross rails and pinned to the hitch. I would reverse that.
I use the 5th wheel to take the hitch in and out of the truck since I don't have a crane. When I drop it back onto the rails I just slide it back and forth till all the holes line up and pin it.
That would be hard to do with the lift kit in place since you would not be able to slide the hitch left or right without it toppling off the lift riser. Since I do this by myself, that would be a catastrophe.
With the lift kit permanently attached to the hitch, the lift kit will slide left and right and the procedure would be the same.
Old 04-22-2011, 10:12 AM   #16
M109Rrider's Avatar
How do you lift the trailer? Blocks between the springs and axles?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 04-22-2011, 10:29 AM   #17
Herk7769's Avatar
In my camper, I have the Al-Ko Torsion axles and a piece of steel rectangular tube stock would have to be welded to the frame between the frame and the axle mount.
Unless done at a dealer, It would most likely invalidate your frame warranty.
Old 04-22-2011, 10:37 AM   #18
M109Rrider's Avatar
I have spring over axle and could stand the trailer being a little higher.
Jason and Billie
Old 04-22-2011, 12:49 PM   #19
Glenn5995's Avatar
If you have leaf springs and they are under the axles, they can be relocated to the top of the axle. This is generally referred to as "flipping the axles". Here is a conversion kit for Dexter suspensions:
httphttp://www.dexteraxle.com/inc/sdetail/1099://
If the leaf springs are already above the axles, you will need to have a sub-frame installed between the spring hangers and the trailer frame. Although there are those which install blocks between the axles and leaf springs, this is not recommended.
With the AL-KO Rubber Torsion axles there are two choices. The first, which Lou addressed, is a sub-frame. This may have frame warranty issues and adds more weight to the trailer and the axles which may be an issue if you are close to capacity. The other option which, I am pursuing, is to replace the axles with axles which have a different drop arm degree. Al-Ko makes them with different degrees on the drop arms and a corresponding lift or drop in the trailer height.
http://www.al-kousa.com/pdf/2000_35F.pdf
http://www.al-kousa.com/pdf/4000_71.pdf
CAUTION: I am providing this information, however one must be careful and informed about any decision they make to lift their trailer as it can result in stability issues if not done properly or if lifted to high.
Old 04-22-2011, 01:14 PM   #20
Thank Lou good advice I will be sure to do that. Just went to harbor freight and got chain hoist for $44.00 and used the garage door crossmember 6x12 on my garage just enough room to to back truckbed back to where hitch is, and lifted out this worked great and no strain trying to lift works just as well to put back in.
