Old 07-29-2015, 02:06 PM   #1
New hitch system...need some experienced advice
I am new to forums so please bear with me. I have been towing smaller TT's for about 20 years and recently purchase a 2016 Grey Wolf 29DBH and towing it with a 2015 Silverado 1500. First couple of trips were local and it pulled OK with a Pro Series™ RB2 Wt. Dist. Kit w/#63970 Shank, 10,000 lbs. (GTW), 800 lbs. (TW). Dealer added a sway control bar and off we went.
On our first "Long Haul" everything was fine until I hit the freeway (I-75) heading to northern Michigan. White knuckle ALL THE WAY! Back end of TT was out of control. I measured my tongue weight before I went and I was at 11% of total weight including cargo (weighed everything when I loaded it).
I called the dealer when we got back and they recommended a second sway control bar or a Reese dual cam set up. I am not real keen on that idea because of changing weather conditions while driving and heard that if you don't lighten up on the sway controls during wet driving conditions it could cause an issue.
Is anyone using the Reese Dual Cam System on a similar set up as mine?
Any recommendations are greatly appreciated.
greyson is offline   Reply With Quote
Old 07-29-2015, 02:29 PM   #2
Adding a 2nd friction type sway bar should help, recommended on 24' and over trailers.
11% on the hitch seems a little low...I like more like 12-13%.
Is your trailer riding level behind the truck ?
Maybe a wrong WDH adjustment ?
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 07-29-2015, 03:14 PM   #3
Trailer is level behind the truck. I did lower one chain link and did not make much difference. I don't mind spending the money on a better system if it will help. Rather be safe and not have my trailer moving so dramatically when a car or truck comes around me from behind. What type of WD hitch system are you using?
Old 07-29-2015, 03:33 PM   #4
DDC
DDC's Avatar
The best systems are made in Michigan (Davidson), google Hensley Hitch, expensive but is the best system you will not need to control sway there will be none and you can drive totally relaxed with one hand even when trucks are passing or being passed. We have had ours for many years and moved it from trailer to trailer when we replaced them.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-29-2015, 04:32 PM   #5
I use a HUSKY 12000 head /1200 lbs springbars and 2 friction type swaybars on a 35+ feet trailer.
Pulling with a F-250...solid as a rock, no sway problems.
Black
Old 07-29-2015, 04:40 PM   #6
I am towing a Coachmen Freedom Express 292BHDS with a Ram 1500 5.7L V8.
The initial friction sway set up from the dealership left much to be desired above 50 MPH or when semi trucks were passing me.
I replaced the friction sway WDH with a Blue Ox and it is a night and day difference. I highly recommend a mid-level sway control system that does not use friction sway bars for trailers of this length.
Preventing sway > attempting to control it once it starts.
A Sway bar was fine for our 19 foot trailer, but once we went bigger (33feet hitch to bumper) it simply is not enough.
I feel MUCH MUCH more comfortable now towing between 60-65 on the highway with the Blue Ox.
I installed it myself. It was not difficult.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 07-29-2015, 04:52 PM   #7
X2 on the Blue Ox.
Papa GLS is offline   Reply With Quote
Old 07-29-2015, 10:32 PM   #8
I can't recommend the ProPride (works the same as a Hensley) enough. You'll notice a huge improvement going to something like an Equalizer 4 point, though.
Old 07-30-2015, 07:30 AM   #9
Thanks to everyone for your input and experiences! It is awesome to be part of a group of people that enjoy camping and share there experiences! Still have not made a decission but getting closer.
Old 07-30-2015, 07:42 AM   #10
Greyson,dont rule out your (TV and or your Trailer Tires)also! If P on TV and trail???? on trailer that can cause Sway Issues! We use a OLD Reese DC system! Youroo!!
hitch
