My 2002 F250 extended cab, short bed, SRW, powerstroke rode pretty well for a heavy duty truck. I had Firestone airbags under it which I basically used to level the headlights when loaded heavy, say with 2 tons on the bed. It was tolerable when empty but really rode quite well with 1000-1500 lbs in the bed.
My 2016 F350 crew cab, long bed dually, Powestroke rides only fairly well until I get at least 2500 lbs on the bed. I do have Firestone air bags with frame mounted air compressor to level the truck if I am moving my dozer around. Otherwise, I just keep 10 lbs of air in the bags to keep them inflated. With the 5er hooked up, I put about 30-35 lbs of air in the bags to level the truck but it doesn't squat much when hooking up the 5er, about 1.25-1.50 of an inch. Empty, it rides really rough but the main reason is that I keep my tire air pressure very high. 75 psi cold on the fronts, 70 psi cold on the rears. That gives me great tread life on the OEM tires.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
