Old 11-15-2018, 09:08 PM   #1
New tires
I have a 30' Vibe travel trailer. Front tires on my F250 became very worn on the outside so I bought two new tires for the back and put the back tires on the front. With the old tires, had no issues pulling the trailer. No sway whatsoever. Now with the two new tires on the back, the sway is bad. Do tires contribute to sway that bad?
dsharper95 is offline   Reply With Quote
Old 11-15-2018, 09:30 PM   #2
Coach
Anything is possible. I take it you've changed brands from the tire that was on the rear previously. Are they the proper load rating for what you replaced and are they properly inflated?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 11-15-2018, 09:53 PM   #3
koller1509's Avatar
Sometimes it just takes running them a little bit to get rid of that squirrelly feeling.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 11-15-2018, 10:19 PM   #4
Oaklevel's Avatar
Not knowing any more information than we do ......... yes it is possible
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 11-15-2018, 10:37 PM   #5
rsdata's Avatar
how about supplying the make and size and load rating... are they P or LT tires ? Then maybe some better info can be given...
What model Vibe do you have?
2014 Shamrock 183
Old 11-15-2018, 10:50 PM   #6
2007 WildCat 32QBBS
18CrewDually's Avatar
Did you verify tire pressure? Low tire pressure in the rear can contribute.
18CrewDually is offline   Reply With Quote
tire, tires
