Old 10-05-2015, 05:10 AM   #21
What happy said, only I'll add even dry weather traction was lacking. They just didn't grip well at all under any circumstance.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 10-05-2015, 08:25 AM   #22
strat56's Avatar
Originally Posted by Happy Vibe View Post
I should not have put your tires the same as mine. As yours are LT and mine are P. I don't like how much movement I get from the sidewalls but some of that comes down to the P tires. The main thing i don't like is the wet weather and in general lack of grip from these tires. I have to be carful in the wet as it does not take much to get them to slide under braking. Again the P and LT are really too different tires.
Thanks for the clarification. I had a 1/2 ton with these tires on it and experienced the less than optimal traction but have not experienced it with the LT's.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 10-05-2015, 12:21 PM   #23
Tom48's Avatar
Originally Posted by strat56 View Post
I put new tires on my TV, Same brand, size and weight rating, Goodyear Wrangler SR-A.
Before I put the new tires on I had towed my TT on a 1200 mile round trip and it towed great. After putting on the new tires, I towed it on a 200 mile round trip and it was terrible, it swayed and bounced and was a horrible towing experience. Both trips used 95S and other major roads and smaller local roads. So I don't think the roads themselves could have caused the problem. I checked and set the air pressure in all TV (60 front and 75 rear) and trailer tires (50 all around) prior to the trip and my TST TPMS said the pressures were good on the trailer and TPMS on the truck ssaid the pressures were good on the truck the whole trip.
The old tires were worn down to the tread ware indicators so they had about 2/32" of tread left on them, the new ones have 16/32" of tread depth, a difference of 14/32" or 7/16".
For the trip home I put more weight on the back of the truck by adjusting the tension on the spring bars and it didn't seem to help much. About 1/2 way home I stopped in a rest area and adjusted the tension again to put more weight on the truck and it helped some with the sway and and bounce but it seemed like I was getting blown around more by passing tractor trailers.
Anyway I have a hard time with a difference in height of 7/16" on the tires making such a big difference in the towing. Has anyone else experienced this? Any other dieas for what might have caused such a drastic change by just putting on new tires?
I didn't like the lack of tension on the spring bars on my WDH after the final adjustment so I've lowered the ball height on the hitch and when I go camping again in a couple weeks I'll see how it goes.
I used to run a load rang D tire on my Passenger Van. Then one year, a brand new set of same model tire seemed mushy. I compared one new tire against the used casing I had saved for a spare on something else. The wore out casing weighed 5 lbs more than the "exactly the same" new tire. When the choice is raise the price or cut back on the product, maybe your new tires are not as well made as the prior set.
Tom48 is offline   Reply With Quote
Old 10-05-2015, 07:09 PM   #24
Check the alignment on the axles on your trailer.. we had the same problem..
the Torflex independent suspension has issues.. sounds like your axles and wheels need alignment.. no one ever told us about the alignment issue.. took us 3 years and doing all kinds of work in other areas to fix the sway problems with the TRAILER, not the truck.. Cost us thousands before we finally looked where the real problem was.. good luck..
LSwesey is offline   Reply With Quote
Old 10-06-2015, 08:27 AM   #25
MtnGuy's Avatar
Can any of you tell me what's wrong with them? Just telling me they are terrible isn't very helpful.
I would like to know, also.
I installed SR-As (P265/70R17s) about a year and a half ago, and I think they are great tires. The SR-As are much better tires than the OEMs that came on my truck. They have a more aggressive tread, can be inflated to 44 lbs (vs. the 35 lbs of the OEMs), and have a higher load rating that exceeds each axle by over 1200 lbs. The do a great job when pulling the trailer, having towed ~2500 miles since installation.
I can tell a difference with a bit rougher ride with SR-As, as I keep them pumped up to about 42 lbs vs. 35 lbs for the OEMs.
My mileage has dropped a bit due to the more aggressive tread.
I don't like the ribbed sidewalls......makes the tires hard to clean.
The 1 thing that I did not consider is the increased height of the new tires, which is what this thread is all about. My trailer still seems to ride level, but I am thinking I need to stop by a CAT scale just to make sure my WHD setup is still good.
Old 10-06-2015, 10:49 AM   #26
My tire does not have an aggressive tread at all. It is a highway tire.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-06-2015, 12:16 PM   #27
MtnGuy's Avatar
I also have a highway tire, but the new 1s do have a bit more aggressive tread than the old 1s.
From this:
To this:
Old 10-06-2015, 05:00 PM   #28
When I think of a more aggressive tread I think more like a K02. Like I said above the traction issue is my biggest complaint, this morning the roads were damp and when I accelerate from the stop light ( I did not accelerate had at all) the tires spun on the white lines.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 10-06-2015, 06:26 PM   #29
Done with this
I have Toyo AT2's. Love them. They were a little squirrely at first, but have calmed down nicely with a few thousand miles on them. Traction in snow and rain are awesome.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 10-06-2015, 08:21 PM   #30
acadianbob's Avatar
What you might be feeling is tread squirm from having full tread height.
Here is another thought. You might have too much weight on the rear of your truck. If your trailer is too high in front, it might be that your ball height on the TV is too high. Lowering the ball and putting LESS weight on the rear axle could help your situation.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
tire, tires, towing
