Old 06-19-2016, 05:29 PM   #1
New to 5W and clueless
DH and I are looking at buying a Silverback 37bh AND a 2014 Ram 3500 Mega Cab with a standard bed. DH has researched but we still have no idea what brand/type/etc of trailer hitch to buy and if this is something we should have the truck dealer to install, the rv dealer to install, or someone else? Obviously we want the correct hitch and best installation for safety purposes but the prices range from a few hundred to a couple thousand and we don't really understand the cost/benefit there. Help!
The SBH weighs about 12,700 dry if that's important here.
bamacampin is offline   Reply With Quote
Old 06-21-2016, 08:26 PM   #2
I like my B&W Companion
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 06-21-2016, 08:46 PM   #3
CaptnJohn's Avatar
I have a Reese Pro 15K slider. Can be purchased without the slider. Not expensive, not fancy. I'm pulling 12,000# with a 2,000# pin. It works great.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-21-2016, 08:54 PM   #4
Left Coast
If your dealing with a dealer, try to find out what pin box is on that unit, and part number.....then while look'n for a hitch, you'll know if it's compatible.....
Old 06-21-2016, 09:13 PM   #5
Oaklevel's Avatar
A whole lot also depends on how much you want or can pay and what type camping you do....... how much travel few miles or thousands of miles. I have had Reese hitches and bought all of them used. Usually any dealer that sells hitches (trailer or RV dealer) can install the hitches.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-21-2016, 10:17 PM   #6
CaptnJohn's Avatar
Just get a new rail kit is suggested by Reese and my engineer friend. Those bolts are suggested to NOT be re-used.
2016 F350 diesel
Old 06-21-2016, 10:26 PM   #7
Left Coast
Also, the height of hitch matters.......trailer needs to sit level when ready to go......so one might need to raise or lower pin box (bolts into place). Is also recommended to have 6" clearance between bed rails and trailer (in and out of driveways).....
Old 06-22-2016, 01:17 PM   #8
That fiver you are looking at does have a nose cone designed for a standard bed so that is a benefit and will work with the 6.4ft bed. So, in that case you can do a standard or a slider.
I like the B&W hitchs. If you have another trailer that requires a gooseneck and you already have a gooseneck hitch in the Dodge, then put on a Reese Goosebox on the fiver and be done.
Good luck.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 06-24-2016, 05:28 AM   #9
shorthorn's Avatar
I am a firm believer in the American made quality of the B&W products! Wouldn't consider another brand that wasn't made in the US (only B&W and Pull rite)
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 06-24-2016, 08:48 AM   #10
Jim34RL's Avatar
Ok, I have a 2008; Ram Mega Cab which has the standard box for that model year 6"-5" but this is one inch longer than your box; which is 6'-4". I have a Reese sliding hitch for my truck and I pull a Cedar Creek 34RL with the Trailair pin box on the trailer. I use the maneuver position on the slider hitch every time I put the trailer in my driveway and in tight campgrounds otherwise it is in the tow position.
I would not pull any 5er without some type of sliding hitch with a short box truck. I have always maintained that there are two types of people who pull a 5er with a short box truck without a slider hitch. Those that have hit the Cab and those that will hit the cab in the future. Which one will you be?
B&W Campion hitch will fit the Ram pick-up bed if this has the trailer package installed. You can also purchase B&W slider hitch that should work for your truck. Find a B&W hitch dealer that you can discuss your hitch needs with.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
