10-28-2013, 12:57 PM
New to the World of Diesel
OK, I bit the bullet and bought an 07 Ram 2500 with the 6.7 Cummins to replace my 03 F150 5.4 gasser. I think this upgrade should really help with my 24 foot Wildwood bumper pull. Looking for some advice on care and upkeep of the diesel as well as any experiences with this type of transition.
BTW, DW thinks this is pure overkill. I said I didn't want to keep pushing the 5.4 to it's limits all the time. We live in Utah and travel a fair amount of time in the mountains.
Would appreciate any advice on maintaining the Diesel
Thanks!
10-28-2013, 01:15 PM
I just want to tag onto this thread so that I can learn too. Thanks.
6.4L Ford Powerstroke
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
10-28-2013, 01:53 PM
Main thing is to know where your water/fuel separator is and drain it.
Other than that keep your filters changed and maybe some fuel additive in the winter to keep fuel from gelling.
I also try not to let the tank get less than 1/4 if it is going to sit for some time.
You will love the towing power VS the gasser!!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
10-28-2013, 01:56 PM
Locate the separator and I'm guessing there are both fuel and oil filters. Oil I'm used to. How often on the fuel?
10-28-2013, 02:00 PM
about every 10K is the norm.
Shane & Antoinette
Good advice - you'll find the filters to be a bit pricey,especially if you use the OEM brand.
And I have been told more once to never,repeat never, run out of Diesel fuel - it's an expensive process to get it corrected.
10-28-2013, 02:03 PM
That is a big 10-4 for sure!!
Shane & Antoinette
10-28-2013, 02:06 PM
Thanks! Pretty standard maintenance issues
10-28-2013, 02:09 PM
I hope you're not speaking from experience here
Do you know what the process involves if you do run out of Diesel fuel?
10-28-2013, 02:14 PM
I did on an old 6 diesel water pump. I have had some tell me it is a non issue anymore but I will stick to never running it dry!!
We had to run the manual pump with a drill until it got up in pressure before it would pump enough fuel to operate the injectors again. No fun!!
Shane & Antoinette
10-28-2013, 03:02 PM
Hello. If you have an owners manual for the truck it is a good read. Good info there. If not...eBay is your friend for getting one. The maintenance schedule is interesting with lube recommendations. I agree good filters a benefit. Be sure and prime your oil filter if DIY.
2017 Puma 297RLSS
10-28-2013, 03:47 PM
The DW is right when she says 'overkill' on a 24'......
But it will not be when you move up to a 35 footer.
Enjoy the Perma-grin of a smoker.
Rule #1) when you pull this small load..... remember that you have something following the truck. It is easy to get up and go and forget you have a "trailer" back there.
2) Learn how to winter start it (and never use starter fluid)
3) Join a Forum with your Make of truck. As with Forest River Campers, this is the Forum to be on. With the nitty-gritty on your Make, Model, Engine, join a 6.7 Cummins Forum. If you had a 'sister' truck of mine, I can give you a gold mine of info. Since you do not, the information will be more general.
ie..... I do not have to run a muffler or catalytic converter.... you do. I am pre 'smog' control, you are post.
I belong to PowerStroke 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Brother Les
10-28-2013, 03:59 PM
"OVERKILL"?????? No such thing!!! Well, only temporarily as you will then find the 'need' to upgrade your camper!! Seriously though, in the winter, use an additive like Diesel Kleen in the White bottle and use the GRAY bottle in warmer times. Try to keep the fuel tank more towards the full side as it stops condensation in the tank, thus reducing the amount of water in the fuel. Congrats on coming to the 'dark; side. I wish you many years of pleasurable towing times in your new rig. Post up a pic or two with it 'working' when you get a chance. Like has already been stated, drain your fuel separator at least once monthly, only takes a couple of minutes to do. Try to buy fuel at VERY busy places that change their pump filters regularly and 'exercise' her frequently. By that I mean drive her at wide open throttle a few times a week, like when starting off from stop lights. Just stay within the speed limits This will exercise the turbo and keep the system in top shape. Most importantly, ENJOY the pwer and ease of pulling with a diesel!
Monty
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
10-28-2013, 04:10 PM
Thanks Bro Les
I just signed up with the Dodge Cummins user forum so we're on the same page there.
The "small" load is tough at times on the ol' 5.4 so I'm looking forward to pulling with something just a bit more capable.
You guys on this forum have spoiled me helping with the RV learning curve. DW thinks it's all the forum's fault for getting me itchin' to upgrade the 03. Now it's the Dodge Cummins crew's turn to to help my learning curve with the diesel upgrade. who knows what she'll blame them for.
Haven't actually taken the Dodge home yet so haven't been able to peruse the owners manual. Hoping to hook everything up and head out for a quick shakedown cruise this weekend. Some quiet late fall camping and a little light reading
10-28-2013, 04:13 PM
Try to put at least 500 miles on her before hauling pulling anything heavy. Most trucks need the rear gears to 'mesh' well before getting a work out.
On a second note. Why does she blame us???? Funny, my wife does the same thing! Says these forums cost us WAY too much!!
10-28-2013, 04:14 PM
Monty
Hello golfmedik, I see that you have a Excursion 7.3. There are may Brothers that have those in the forum that I posted in my post before yours. Stop by and tell us some of the mods that you have done or might in the future.
Brother Les
Agreed!! No such thing as overkill. I pulled a 25' TT with a 1/2 ton. It was laboring the truck I know at times. Overlapped pulling the TT with a 350 diesel for about 5 months before getting the 5th wheel. A world of difference is an understatement as anyone who has done it knows. All good maintenance advice there. Now that you have the ability you will start to look at bigger and heavier. We know you will!! Enjoy the big power.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
10-28-2013, 04:16 PM
Will do!!
10-28-2013, 04:17 PM
Why would he need to put any miles on the TV before towing?? The truck is a 2007. You done good by getting a diesel. Enjoy the extra power AND better fuel economy over your 5.4L gasser.
10-28-2013, 04:19 PM
WOW! Totally missed that part!!!! Dang, I must be more tired than I thought!
