Old 08-21-2012, 07:42 PM   #11
I think you will be fine. You likely will be pretty close to your GVW, maybe a few pounds over. I'd be surprised if your TT weighs more than 7000# loaded, well under the rated capacity. I am guessing even with those gears the truck will get you where you want to go as long as you don't need to do 75 mph up every hill. I pulled a trailer that weighed roughly 500# less than yours with a 240 hp Ford Explorer with 3.73 gears without any trouble. Your truck has a lot more hp and torque. Too many people on this forum think you need a F450 to pull a popup.
2012 Lacrosse 318BHS
2010 F-150 Max Tow
21C1 is offline   Reply With Quote
Old 08-21-2012, 07:52 PM   #12
You may be a few hundred pounds over your GVW. Our F150 weighed 7540# with our TT attached and family aboard. Family and dog are probably 350#. Our TT has a listed dry tongue weight of 810#. Your truck may be lighter than mine by enough that it will be closer than I think.
2010 F-150 Max Tow
Old 08-21-2012, 09:07 PM   #13
Scratch's Avatar
Thanks much for the info...
Per the book, the basic dry truck weight is 5374 and the trailer dry weight is 5805 for a combined weight of 11,179. If the GCVW is 14,000 (per the book), as I understand it, I have 2821 lbs. for people, pets, gas, supplies etc?
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 08-22-2012, 05:48 AM   #14
Yes, but you need to weigh your truck loaded like you're going camping. Then look at the yellow sticker on the camper and add 800-1000 lbs for your groceries and stuff to that. Subtract that from your GCVW and go from there. Don't rely on the dry weights, they're more then likely wrong.
Len & Cheri is offline   Reply With Quote
Old 08-22-2012, 06:28 AM   #15
If you go to (Pikes Peak) stay in the right lane and keep your right foot to the floor! Ps. not the Best towing gear. Youroo!!
youroo is online now   Reply With Quote
Old 08-22-2012, 08:57 AM   #16
Scratch's Avatar
Thanks Len & Cheri;
Love that Mustang! Got an '07 Cali Special in the garage...
Scratch sends...
'14 nights camped:
Old 08-22-2012, 08:59 AM   #17
Scratch's Avatar
Hey Youroo,
A couple camping buddies here said to lock out 6th gear in the truck's Tow/Haul mode and, if necessary, 5th and 6th gears in the mountains to ease the tranny. Plenty of horses and torque for the upward pull. The MPG will stink, but we'll spend less than 60 days on the road during any given year so we'll just suck it up and enjoy the non-towing MPG, I guess...
Scratch sends...
'14 nights camped:
Old 08-22-2012, 12:51 PM   #18
Here are my two cents. Put the truck in tow/haul mode and go. Concentrate on keeping everyting between the lines on the pavement and dodging the less than capable drivers out there. Let the transmission do what it is designed to do...shift! In my '10 F150, tow/haul mode does not lockout 5 or 6th gear. The manual also doesn't state anything about locking out either gear. I think you can only lock out 4th though 6th by selecting 3 with the lever. If Ford Engineers what 6th gear locked out they would have programmed tow/haul to do just that.
Gas milage might not be pretty but it has to be better than my 5.4L pulling 9000#. On a really bad day I see 7 mpg on the highway. On a good day on the highway I might see 9 or 10mpg. I am not complaining, that 1/2 ton pickup is towing a gross combined weight of about 15,500# down the highway at 65 mph. Don't even look at the mileage just fill up when it reads empty and enjoy camping in the new rig!
2010 F-150 Max Tow
Old 08-22-2012, 01:16 PM   #19
Scratch's Avatar
Thanks 21C1. I learned a lot by (finally) reading the F-150 owner's manual and talking with the Ford rep this morning.
You're right about the Tow/Haul mode. By going there, the tranny will automatically select the appropriate gear, although it could make the tranny work harder by changing frequently between the three overdrive gears (4, 5 & 6).
The tranny is an SST which allows the driver a second tow option to shift from D (Drive) Tow/Haul mode to M (Manual) mode with gear lockout provisions. (I was wondering what that 'M' meant on the shift select panel. In the 'M' mode, 6th, 5th, and/or 4th (overdrive) gears can be locked out as desired/necessary for hills/steep upgrades. It also allows to select gears manually using plus/minus buttons.
The Ford guy said with the 3:15 gears, I'll probably use O/D lockout options more than the guys with 3:55 or 3:73 rears and will probably gas up more often.
Scratch sends...
'14 nights camped:
Old 08-22-2012, 02:30 PM   #20
MilCop4523's Avatar
Originally Posted by Scratch View Post
We've been researching 1/2 ton trucks and liteweight travel trailers for two years as we entered retirement ready to do some long-awaited traveling.
Has anyone here towed using the 3.15 gears? Just looking in advance to see what we can expect.
Thanks in advance...
Sure have and did't really notice any lack of power in ours. Swapped out the oem air for cold air intake and goes like snot.
Pulling a 27 RKSS 2012 Salem 33 feet overall with 6400 dry weight.
We hauled to NH for the July race and had to slow down for 1500 Chevs and 5.4 Fords. And that ws with full water tank for another 333 lbs - plus 12 more gallons in containers in te box withteh generator and spare fuel. No one seemed to be hauling with a Dodge.
Just watch your speed.
Name:	truck and trailer.jpg
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
