Old 08-22-2012, 04:35 PM   #21
Scratch's Avatar
Thumbs up
Originally Posted by MilCop4523 View Post
Sure have and did't really notice any lack of power in ours. Swapped out the oem air for cold air intake and goes like snot.
Pulling a 27 RKSS 2012 Salem 33 feet overall with 6400 dry weight.
We hauled to NH for the July race and had to slow down for 1500 Chevs and 5.4 Fords. And that ws with full water tank for another 333 lbs - plus 12 more gallons in containers in te box withteh generator and spare fuel. No one seemed to be hauling with a Dodge.
Just watch your speed.
Thanks. I needed that!
Mine's a 4X2. Your 4X4 has a 3:15 rear?
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 08-22-2012, 07:48 PM   #22
Capsfloyd's Avatar
I have a 09 rambox crewcab 5.7 Hemi and 3:21 Rearend
I tow a TT. Around 7,000 lbs
Never look back , put it in tow/haul mode and go on
When not towing the best I get is snot 21.5 mpg on the highway
If you tow 6-7 times a yr , youll be fine ,
Go for it Turn those turbos loose
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 08-22-2012, 08:16 PM   #23
Originally Posted by Scratch
Thanks Len & Cheri;
Love that Mustang! Got an '07 Cali Special in the garage...
Thanks! It's always nice to have more Mustang Lovers around Do you have photos of your Cali in your album?
Len & Cheri is offline   Reply With Quote
Old 08-22-2012, 11:11 PM   #24
Scratch's Avatar
Same situation. That's what I'm, talking about! Thanks Capsfloyd...
Scratch sends...
'14 nights camped:
Old 08-22-2012, 11:21 PM   #25
Scratch's Avatar
Here's a pic of 'Gus' in the stable:
Scratch sends...
'14 nights camped:
Old 08-23-2012, 12:59 AM   #26
The tranny is an SST which allows the driver a second tow option to shift from D (Drive) Tow/Haul mode to M (Manual) mode with gear lockout provisions. (I was wondering what that 'M' meant on the shift select panel. In the 'M' mode, 6th, 5th, and/or 4th (overdrive) gears can be locked out as desired/necessary for hills/steep upgrades. It also allows to select gears manually using plus/minus buttons.
The Ford guy said with the 3:15 gears, I'll probably use O/D lockout options more than the guys with 3:55 or 3:73 rears and will probably gas up more often.
Close. In 'D' you can lock out individual gears (starting at 6 and working down.) In 'M' you make all the changes up shifts and downshifts. My 5.0 with 3.73 gears rarely goes into 6th while pulling my trailer (but about 1500lbs heavier than yours.)
Also tow/haul mode is not needed on straight and level travel and is made more for hilly areas. If you have the LCD screen in the dash there's an info screen somewhere explaining it in detail.
Have fun.
Guessboy3 is offline   Reply With Quote
Old 08-23-2012, 04:00 AM   #27
great white's Avatar
Listed "dry weights" as seldom accurate.
Depending on manufacturer, dry weight is without batteries, propane, etc. some are even worse as they dry weight can be before options like slides, oven, etc.
You can probably add around 500 lbs right off to the listed weight for the trailer.
Unfortunately, dry weight for vehicles is the same. Ie: no oil, fuel, brake fluid, batteries, coolant, etc. add another 500 lbs.
Only real way to know what you're dealing with is to scale it empty and then loaded.....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-23-2012, 05:39 AM   #28
Very nice! Super clean
Old 08-23-2012, 08:37 AM   #29
Scratch's Avatar
Have fun.
Greatly appreciated; I'm learning!
Just to make sure: in 'D', press the + or - buttons to lock out or add back the O/D gear?
Tow/Haul for hilly/mountainous terrain
Seems the 'M' setting would be best used in town while towing to take advantage of extending the torque available in 1st gear etc?
Scratch sends...
'14 nights camped:
Old 08-23-2012, 08:39 AM   #30
Scratch's Avatar
Yes sir... I need to get to a scale, for sure so I know exactly what I've got.
Scratch sends...
'14 nights camped:
