Old 01-04-2010, 06:59 PM   #11
Dave_Monica's Avatar
With the air autoride, how can you tell when you have enough tension on the spring bars of the hitch?
Old 01-04-2010, 09:15 PM   #12
Grape Escape
Hi Dave
No sway. Had a few instances where I did have some swaying and just tightened 1 more link. Worked fine.
Bet you can't wait for the new 5'r
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 01-06-2010, 07:14 AM   #13
Head Rambler
To echo what others have said. On that length RV you need a hitch with built-in sway control. Either the Equal-i-zer or Reese Straight-line (dual cam) will do nicely.
As for the air level on your Yukon you have to turn it off when setting up the hitch but once it's set up you leave it on for towing.
If you got that hitch from a dealer, see if you can take it back and trade for the proper one. Once you've got a proper hitch come back and we'll help you with checking the setup. Level to slightly nose down is the proper attitude when towing.
An added note: Be careful adding casters to the frame at the rear. Frame manufacturers don't recommend it because it stresses the frame and can warp or even crease it. They put those wimpy triangles on the rear mostly as noise makers. When you scrape those they make a lot of noise and bend easily but they don't tweek the frame.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
