Old 10-17-2016, 07:02 AM   #21
mark0224's Avatar
Sorry miss read it is tow is bout 12000 by time everything is loaded. It still is 4000 lbs more than I need so should be good
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-17-2016, 09:28 AM   #22
Yes, you will be good. Enjoy your new truck.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 11-02-2016, 02:00 PM   #23
mark0224's Avatar
New truck just got its tonneau cover, still waiting on the bed liner that was supposed to be delivered today.
ID:	124528   Click image for larger version
ID:	124529   Click image for larger version
ID:	124530   Click image for larger version
ID:	124531   Click image for larger version
Old 11-02-2016, 06:28 PM   #24
mark0224's Avatar
Finally got the trucks bed liner at 630pm took a bit longer to put in by flash light but it's in will post pics tomorrow.
Old 11-02-2016, 07:52 PM   #25
Great for having the new truck! I'm still finding new gadgets and neat stuff almost every week. I got the 200 amp alternator on mine, and the trailer tow connection does charge the trailer battery whenever the engine is running. I believe it has a 40 amp fuse protecting it , and a relay, as do all of the trailer turn signal and marker lights, and so on. If you think you might want to put a camera on the back of your trailer, the back up light connection DOES work. The bed liner is always nice, but they do tend to allow some things to slide around. You can order a Rhino Liner type from the factory. However, I opted to have a color keyed one installed (my truck is white) by a local body shop, and it has been excellent. Stuff stays where you put it. The factory back up camera is concealed in the tail gate handle, by the way. A few months after we took delivery of the new truck, we traded the fifth wheel in on a Class C. Go figure.
Photo Lab is offline   Reply With Quote
Old 11-02-2016, 08:18 PM   #26
Retired JSO's Avatar
If the truck is equipped with the Ford brake controller, the truck will keep up with trailer tow mileage in the dash display. It took us 4,000 miles towing before I found and learned how to use it.
Retired JSO is offline   Reply With Quote
Old 11-02-2016, 10:11 PM   #27
mark0224's Avatar
This bed liner is two parts, plastic for the walls and rubber for the floor so things won't slide.
Old 11-03-2016, 04:50 AM   #28
Big1's Avatar
Congrats! Awesome setup.
2016 Dodge Ram 2500 6.4L Hemi /with 4.10 gears/Firestone air bag Ride Rite
2016 Denali Dutchmen 287RE
Big1 is offline   Reply With Quote
Old 11-03-2016, 09:02 AM   #29
mark0224's Avatar
Finally went out this morning ( pouring rain) to get some tools I left in the back of my truck. Here's the bed liner and everything was high and dry tonneau kept all the rain out overnight. Liner is a Dual Liner sides are plastic and bottom is rubber about a 1/2 inch thick so the aluminum bed should be safe.
Old 11-03-2016, 09:38 AM   #30
Mark, I must have missed something in this thread. Your title, 2016 F250 which I have does not have an aluminum bed.
tow vehicle
