Old 03-31-2014, 04:50 PM   #11
ironj's Avatar
Oh for sure 40 psi is way
Too low on an E...even unloaded. ..he is running p tho....my point was regardless of tire poor hitch/wdh bar setup will render an otherwise adequate tv unsafe..
Hell 40 psi is unsafe unloaded on an e tire imho
sent from fat fingers via a space dish thing with no regard to grammer.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 03-31-2014, 05:00 PM   #12
turnerpa's Avatar
I'm going to have to go against the 40psi is too low and unsafe unloaded. I have always ran 10ply tires aka load range E on my 1/2 tons and unloaded I had to run 35-40psi all the time for tread wear purposes. ALWAYS as soon as I loaded I upped the pressure to 70-80psi. Jmho though.
turnerpa is offline   Reply With Quote
Old 03-31-2014, 05:06 PM   #13
ironj's Avatar
I dont know off the top of my head the axle weights a 1/2 ton would have...but even then it may be low based on manufacture recommended psi's....
sent from fat fingers with no regard to grammer via a space dish thingy
Old 03-31-2014, 06:12 PM   #14
Disney camper
camper67's Avatar
Truck tIre says max is 44psi. I run 36 unloaded and pump them up to 40psi when towing.
camper67 is offline   Reply With Quote
Old 03-31-2014, 06:14 PM   #15
turnerpa's Avatar
That sounds right and I know tires are not in the budget right now but when they are make sure to get load range E tires and you will notice a huge difference
Old 03-31-2014, 06:31 PM   #16
GoDuke1's Avatar
New tow vehicle
I noticed my trailer towed better with it loaded with our stuff in it vs towing it home empty. Your experience might vary.
2012 F150 SCrew EcoBoost
2013 Salem 27RKSS
GoDuke1 is offline   Reply With Quote
Old 03-31-2014, 08:48 PM   #17
Disney camper
camper67's Avatar
It's finally getting warm enough to play with the new toy
Old 04-06-2014, 09:25 PM   #18
Disney camper
camper67's Avatar
After adjusting the hitch, I'll have to take the scenic route to get some hwy driving to the local campground before we take off on a long trip to FL this summer
Old 04-25-2014, 08:22 PM   #19
Disney camper
camper67's Avatar
Got the ball height adjusted and pumped up the tires to 42psi (max is 44) for a trip back to the dealer for warranty work. I'll see how it tows.
Old 04-26-2014, 01:09 PM   #20
Disney camper
camper67's Avatar
Ok... And wow!... What a difference. The truck and trailer feel like one. I never thought 1.5 " lower on the ball and full psi on the tires could make such an impact. Now I know we made the right choices in the new TV and TT.
Oh and the Ecobeast rocks!
tow vehicle
