Old 04-26-2014, 02:01 PM   #21
B and B's Avatar
Glad to hear you have it worked out! The downward force makes a big difference. Hauling more with my fiver the addition of LT rated truck tires stiffened the back end up a lot, only 1.5 inches of drop when hitched over dry. All the best in your travels! Despite what others say until you tow with a EcoBoost you really can't say how well it hauls!
Old 04-26-2014, 02:44 PM   #22
Phat Phrog Stunt Crew
elind's Avatar
When I got my last TT the dealer hooked up the hitch and said it was good. But it wasn't good enough for the Sierra 1500 and 34' LaCrosse. I pulled 2 or 3 links up on the chains and then it went down the road with very little sway.
My thoughts are to max out your tire pressures (TT and TV) and then try adjusting your chain links up and down to see how things change. I remember my first ever TT pull with a SUV was frightful without a clue on how the hitched worked. After a short time of adjusting the hitch, I ready to go cross country.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-06-2014, 07:38 PM   #23
Disney camper
camper67's Avatar
So I'm sure I have the WDH worked out... The dry 6,000 TT has a toung weight of 950# works out be 15.8%. So I figure camp ready it will be around 14% if careful to load over the axles or to the back.
My question is this too much toung weight and would that effect the way it tows?
camper67 is offline   Reply With Quote
Old 05-08-2014, 11:07 AM   #24
dsrace's Avatar
Originally Posted by camper67 View Post
Got the ball height adjusted and pumped up the tires to 42psi (max is 44) for a trip back to the dealer for warranty work. I'll see how it tows.
well if this is your truck tire you are talking about with a max pressure of 44 psi then you have really light duty tires that are actually found on most mid size suv's. like trail blazers or explorers or kia sorento's. a good set of 10 ply tires would make a big diff imo in stability and reduce sway. also if your camper came with load range c tires then it should have d's on it and I have seen several with the c's ...... most boats come with c's and d's. load range E would be stout but might make it a bit bouncy empty. I know it did mine but once I load my sand rail and gear in it's smooth again. the load range d's that came on mine were no where near up to the task and bulged empty at 65 psi new on the dealership lot. at 80 psi my 10 ply barely bulge and it does help with sway. but glad to hear your making progress in the right direction!
'99 f350, quad cab long box, dually, 6 speed manual, gently mod'd.
2011 wolf pack 295 with full susp now!
dsrace is offline   Reply With Quote
Old 05-08-2014, 11:53 AM   #25
My truck has a switch for the TPMS system that allows me to switch between light and heavy loads. Light load puts the rear tires at 45psi. Heavy load is 80psi. When towing at 45psi, the back end is more squirrley because of the additional tire flex. At 80psi, it's a world of difference. But then, 80psi when empty is a bumpy ride.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-08-2014, 11:56 AM   #26
TURBS's Avatar
This is new to me.
More info?
TURBS
Sabre owners united!
Old 05-08-2014, 12:00 PM   #27
Originally Posted by f1100turbo View Post
This is new to me.
More info?
TURBS
It's specific to the 2013 Ram heavy duty trucks. They removed it on the '14 trucks, and a lot of people are P'd off it's gone. I'd certainly miss it. All the switch does is tell the TPMS system what pressure the rear tires should be at. 45psi or 80psi. Manual says "heavy loads", but doesn't define what that means. My trailer is about 925 pounds tongue weight, of a 2250 pound payload capacity, so not quite half way there. It also makes a difference when I'm carrying my quad in the bed, which is about 750 pounds.
Old 05-08-2014, 01:59 PM   #28
dsrace's Avatar
well that's nice it keeps the system functional and keeps the light off. so the factory is promoting running tires half inflated rather than better suspension lol def the cheaper way for them. lol
Old 05-08-2014, 02:12 PM   #29
I think that's one reason they ditched that option in the '14s. They now have rear coil suspension rather than the leaf packs I've got in mine. Apparently the ride is much better that way, and maybe the 45psi setting is unnecessary with the coils.
Old 05-08-2014, 04:10 PM   #30
Disney camper
camper67's Avatar
Yeah... I don't know why they sell trucks and TTs with tires they know aren't rated for loads... Wait I do know. So they can have a chance to sell you on upgrades.
tow vehicle
