Old 09-10-2013, 02:34 PM   #1
New Trailer Set up
Just went and picked up my new trailer today I have had one before but I have never had to set up my WD hitch. Just curious what some of you that have been doing this for a while think? It looks good to me but I thought I would put it out there for everyone to have a look at and tell me what they think. Thanks, Jake
Name:	2013-09-10 13.46.38.jpg
ID:	39521   Click image for larger version
Name:	2013-09-10 13.47.11.jpg
ID:	39522   Click image for larger version
Name:	2013-09-10 13.47.44.jpg
ID:	39523   Click image for larger version
Name:	2013-09-10 13.47.58.jpg
ffwood is offline   Reply With Quote
Old 09-10-2013, 02:37 PM   #2
Experienced Newbie
Looks Ok to me. However, is the camper loaded for camping or empty? If empty you may need to readjust the hitch again.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 09-10-2013, 02:54 PM   #3
Patches's Avatar
This link might help;
How to Setup a Weight Distributing Hitch | eHow
If your present hook up measures out like this then you should be OK.
Always check when the whole rig (truck and trailer) is loaded and ready to go. When loading the tow vehicle, keep it level. Also don't put a lot of weight in the rear of the travel trailer. Keep the recommended tongue weight as close as possible. Me I tend to error on the heavier side of the recommendation. Just by a little.
"Full Timer" with "Boon Docking" in the desert southwest being my drug of choice. Well, that and really cold beer.
Patches is offline   Reply With Quote
Old 09-10-2013, 03:07 PM   #4
Triguy's Avatar
Its hard to tell from the pictures because they're at an angle but the attitude shots look okay for both the trailer and the TV. But, here are some questions:
How did the before and after front and rear wheel well measurements come out? Were they within the specs given in the Equal-i-zer manual and also in line with Chevy's recommendations (especially for the front wheel well)?
Have you weighed the tongue weight and how is that relative to the fully loaded trailer?
How was the test drive? Any tail wagging the dog? Was the steering solid or did the steering feel floaty?
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-10-2013, 03:52 PM   #5
The setup looks good visually. Some small adjustments. The L brackets should be at right angles to the trailer frame. I think the driver side is off a bit. The equalizer brackets will tend to walk (creep) along the frame if not tightened to spec. Also check if you have at least 3" of overhang from end of bar to L bracket.(hard to tell from pics)
Looks like your setup is good ... now to weigh the rig for final confirmation
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 09-10-2013, 10:07 PM   #6
The trailer doesnt have everything in it yet and I Know that I might have to adust it when I do. My front wheel well measurement only changed a half inch with no wd hitch hooked up. I have only taken it around the block with the new hitch hooked up because my brake controler decided to crap out on me. I will take it out tomorrow for a drive and see how it does.
Old 09-11-2013, 12:25 AM   #7
Grizzlygibbs's Avatar
You are at the top of that stinger and if it were mine, I would flip it for ground clearance. Other than that, listen to everyone else about the actual setup, once you get the load on it will be different, especially with fresh water and any waste if there are no dumps.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 09-11-2013, 04:10 AM   #8
Mister's Avatar
Load up the trailer, and put enough weight in the bed to simulate an average trip. Take your measurements then and visually look to see angles of the brackets and the trailer itself.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
Old 09-12-2013, 01:13 PM   #9
thebrakeman's Avatar
The look is the easy part. Trailer looks level (but you should check with measurement from road to frame, front and back. Should with within 1", or maybe a bit more for that long trailer. Weight bars look parallel to trailer A-frame...check.
You want to measure the wheel well heights 3 times. No trailer, with trailer (WDH not engage), and with trailer (WDH engaged). The optimal goal is to have the 3rd front measurement the same as the 1st front measurement. Any less (higher front measurement), and you will have less front wheel stability than you should.
thebrakeman is online now   Reply With Quote
Old 09-12-2013, 02:10 PM   #10
avolnek's Avatar
I also suggest having the trailer rake/tip/lean forward/towards the TV a little. An inch or so is plenty. A trailer with the tongue up higher will have a greater tendency of wandering or swaying... It doesn't need to be much rake but some is preferred, IMO at least...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
