Old 08-30-2015, 10:12 AM   #1
New truck ball height ?
hello all, we just picked up a new chevy 2500hd and traded in a gmc 1500 truck, before trading in I measured the ball height on the gmc now if I adj the ball height the same on the new truck will that get me in the ball park ? thanks joe
joe in pa is offline   Reply With Quote
Old 08-30-2015, 11:17 AM   #2
Its a starting point - Your new TV wont sag as much as the old one thats for sure.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 08-30-2015, 11:32 AM   #3
Georgia Rally Coordinator
aceinspp's Avatar
Yep should get you close and probably less sag on the truck due to heaver springs. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 08-30-2015, 11:47 AM   #4
DDC
DDC's Avatar
I just got a new 2500 HD chev.to the height difference is huge, I have a Hensley and have gotten a replacement shank that takes it from a two inch drop to an eight inch drop, have not connected it yet so don't know how it will work yet.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-30-2015, 11:50 AM   #5
aceinspp's Avatar
Depending on what type receiver set up you have hopfully you can adjust for right height. Later RJD
Days camped 2017 62
Days camped 2018 67
Old 08-30-2015, 01:26 PM   #6
i just went from a 2013 ram 1500 2 wheel drive to a 2015 ram 2500 4 x 4 big difference had to get a new drop for my hitch truck and camper are level. the truck didn't move when i hooked it up with the original set up but the back jacks were about 4 inch off ground all the way up
locogk is offline   Reply With Quote
Old 08-30-2015, 02:27 PM   #7
ben31's Avatar
That should be a decent starting point. Get on youtube and watch a video on how to level a weight distribution hitch. It is fairly easy. You just need somewhere, which is somewhat level.
Congratulations on your new truck!
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 08-30-2015, 03:02 PM   #8
Hitch height
Just one more thing is the new GM 2500 HD HAS A 2 1/2 receiver opening. They do give you a adapter but it does flex more with the adapter and weight distribution hitch and bars. Bottom one if you need a new shank get a 2 1/2 inch shank.
speedozeke is offline   Reply With Quote
Old 08-30-2015, 03:28 PM   #9
Flybob's Avatar
I think I would start with 2" lower, I upgraded from an 05 2500HD to the 2015 2500HD Z71 and I have almost no rear end sag without the WDH bars installed. Had about 2" drop before bars instaled on 05.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-30-2015, 03:39 PM   #10
The beginning point to set up a WD hitch is to set the ball height the same as the TT coupler when the TT is level.
magpi26 is offline   Reply With Quote
truck
