Old 05-31-2015, 07:20 AM   #11
f5moab's Avatar
I was told to lube, twice a year or more if traveling a lot, through the zerk fitting and disassemble and repack every three years or about 20K miles. But the most important thing I was told was to use a MANUAL grease gun. don't use an air powered grease system like auto dealerships use.
After three years I can say my seals held up perfectly.
f5moab is offline   Reply With Quote
Old 05-31-2015, 07:54 AM   #12
WSY DD693's Avatar
Always good to hear advice and experiences from fellow TT folk
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
Old 05-31-2015, 08:24 AM   #13
f5moab's Avatar
NOT advice, experience. But if not for the cleaning of the bearings, races, etc., and the mess of repacking bearings, it does not really add much more than an hour, per wheel, onto the entire procedure.
Old 06-07-2015, 08:56 AM   #14
Ddubya's Avatar
I am curious as to where the grease goes? If the dealers say to grease the bearings twice a year the existing grease must be leaking out somewhere?? If so where?
Do these dealers add grease to their cars and trucks twice a year? I think not.
If the grease is escaping the trailer hubs there is a problem that should be addressed before adding more grease.
Ddubya is online now   Reply With Quote
Old 06-07-2015, 09:37 AM   #15
f5moab's Avatar
I understand your statement, cause I have often thought it sounds ridiculous to have to change out the grease in a trailer hub when newer vehicles can go thousands of miles with sealed hubs. And considering when I was younger, an oil change included a lube of the hubs seals; prior to the newer sealed systems. And that was usually at about every 3K. One reason is that oil/grease has greatly improved in the past twenty years.
However, the zerk fitting on the end of the axle sure makes it easy to lube.
However, my limited experience is it doesn't go anywhere, after the initial lube is done.
It appears, that from the factory, they lube the bearings add a little grease to the spindle, assemble and ship. When I added grease to the zerk fitting the first time, it took a heck of a lot of grease before the grease started to come out the area around the zerk fitting. From then on, when I did the addition of grease, it came out almost immediately.
It does appear to get dirty or worn and every year I would add lube until nice clean stuff started to come out. (Talk about a mess!)
This year, when I switched out the brakes and springs, I did just what I assume the factory does, and that is lube the bearings (using a bearing lube thing I purchased), greased the spindle and installed the drum/hub. I then added more grease through the zerk fitting (as described in the instructions from AL-KO), and it took a heck of a lot of grease before the grease started to exit around the zerk fitting.
So, I don't believe the lubing every spring, at least in my experience, is not adding grease that has disappeared as much as making sure it has grease, and basically changing out as much as possible every year.
Old 06-07-2015, 10:27 AM   #16
Ddubya's Avatar
I had the experience of checking my new hubs and found the hubs almost void of grease. I also found a leaking seal. I pulled all four hubs,cleaned,repacked and greased per factory specs.
I still do not understand why the grease would need to be replaced periodically if using a high quality grease other than maybe poor quality bearings are wearing and leaving metal residue inside.
Common sense would dictate checking the hubs periodically as a CYA measure just to have piece if mind.
Old 06-07-2015, 10:49 AM   #17
f5moab's Avatar
In my opinion, I'm going to guess they use grease that barely meets specs. (Just like tires, axles, etc., the bare minimum.)
Now that I have completely repacked and filled the bearings and hubs with Mobile 1 Synthetic grease, I won't worry about changing the lube, just add a squirt or two a few times a year. And probably every three years, do a complete cleaning and repacking....
Old 06-07-2015, 10:49 AM   #18
SKnight's Avatar
Cleaning and repacking isn't just about replacing high quality grease, it's about inspecting bearings and seals that are under much higher loads than cars and trucks with the modern permanently lubed bearings. My camper has about 10,000 pounds on the wheels, or 2,500 pounds per corner, my 2015 Equinox weighs about 3,800 pounds or about 950 pounds per corner. Huge difference in load.
So it's a good idea to pull and check things every now and then, and repack with fresh grease while you're there. I'm not a fan of using the zerk, it fills the hub space with grease which doesn't do any good and could pump grease past the seal causing brake issues. Lots of people have good luck with it, that's just my perception of them.
bearings
