Old 05-22-2015, 08:05 PM   #1
New TT and bearings
Decided to check the wheels, hubs, and brakes on our new Salem Hemisphere 302FK.
Jacked up the wheels and adjusted the brakes.
One spindle took a lot more grease than the others. (pumped grease while turning wheel)
Checked the torque on all lug nuts.
Checked for slop in the bearings.
Checked the tire pressures.
Going to be happy campers on Wednesday.
Dennis & Beth
Dewitt, MI
2016 Salem Hemisphere 302FK Showstopper
2017 Silverado 2500HD Duramax, LTZ, crew cab, Z71, 20" tires, TST 507 tire pressure monitor
DiverDennis is offline   Reply With Quote
Old 05-22-2015, 08:10 PM   #2
f5moab's Avatar
I'm going to guess that when they install the hub to the spindle, they pack the wheel bearings add some extra grease around the front/rear bearings and ship it. When I did mine the first time, I used a tube for both sides. I do not believe that they add grease through the EZ lube system at the factory, so there is a fairly large empty void around the spindle, between the bearings.
f5moab is offline   Reply With Quote
Old 05-22-2015, 09:10 PM   #3
That would make sense. Thanks for the reply.
Old 05-23-2015, 07:54 AM   #4
Ddubya's Avatar
Just a caution. I checked my hubs recently and found a rear seal that was leaking. This after less than 2k miles.
Ddubya is offline   Reply With Quote
Old 05-23-2015, 08:00 AM   #5
f5moab's Avatar
Easy to remove a hub and check the seal to see if leaking.
Old 05-23-2015, 08:03 AM   #6
SKnight's Avatar
I've got a big trip coming up in August, I'll be doing this sometime in late June, plus I'll be repackaged the bearings instead of just pumping them full. This way I know I'll have one brand of good grease in there.
Old 05-24-2015, 08:01 AM   #7
Good basic info here. I use Lucas Red 'N' Tacky on my boat trailer so it will also go in the TT.
Old 05-27-2015, 07:50 PM   #8
I was just looking at buying grease as my bearings need to be cleaned and repacked, And I looked at red-n-tacky and did not purchase it because it is not rated for well bearings, did purchase the Marine version from Lucas. Just thought I should help out.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 05-27-2015, 09:03 PM   #9
f5moab's Avatar
Strange! I won't use Lucas red and tacky cause I only use Synthetic, but know people who do, and it has the GC-LB label.
http://lucasoil.com/pdf/TDS_Red-Tacky-Grease.pdf
Old 05-31-2015, 06:19 AM   #10
WSY DD693's Avatar
My RV service folks advised re-packing the bearings annually
or every 8,000 miles is a better way to go. Many times pump lubing the bearings can cause seal damage.
Not being a certified mechanic, for the price of having them repack the bearings as part of a seasonal pre-trip checkup is worth the minor cost to be worry free for our long journeys.
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
bearings
