04-10-2016, 04:33 PM
#21
Just a member
Originally Posted by pal216
Am I way out of my league attempting to pull this TT with my truck or if I am wise about what I put in the truck vs what I load in the trailer before hitting the road I will be in good shape.
Mike, I think you'll be ok but you need to load er up and get to the scales. Advertised and even the sticker weights for some of these TTs can be off actual weight by hundreds of lbs. The only way to know for sure is to weigh the rig.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
04-10-2016, 04:38 PM
#22
Hello,
My F 150 SCREW with Eco was Max GVRW 7690 and had CCC of 1650. I towed a Fifth Wheel with it overloaded, traded for F 250. There is one one good thing it appears your rear springs are the Max Package. When I had my 2703 Rockwood TT with the Cap and gear in the back I was maxed out on the truck as well.
If you must use this truck thinking short term only ...Pack Light, use WD hitch to level out, If you have a Cap/Tonneau take it off to save CCC, half tank of gas etc Nothing in the truck bed you can sneak buy but barely. You need to make sure you have proper transmission cooling, might need a extra add on unit.
This is of course you choice.
Kenny said scale it, yes for sure that is needed to see what you have.
It is common for F 150 to have that a low a payload without Max tow/ Towing Pkg.
B and B
04-10-2016, 04:42 PM
#23
Originally Posted by Kenny kustom
The only number that means anything is gvwr.
The rest is pulled out of thin air.
A real scale will tell you everything you need to know.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Axle ratings are pulled out of engineering.
04-10-2016, 04:45 PM
#24
When I bought the truck 4 years ago, I never envisioned purchasing a TT. At the time we had zero kids and I only hauled/towed my ATV and 19 ft boat. Hindsight is 20/20 and if I need to step up in trucks with higher numbers where I need them I can do that. However, I would rather not buy a new truck if I can avoid it. If I can be smart about what I pack and where I pack it and be within the ratings of my truck that is where I would like to be.
04-10-2016, 05:02 PM
#25
I really wish people would stop telling people to go over their ratings, just because they do it themselves. It's really careless and stupid.
Give the information needed. Let them make their own decision.
" oh yea! 2klbs over gross. No problem! That guy on the forum said I'd be ok! "
2016 Sabre 36QBOK
2017 Dynamax Isata 4
04-10-2016, 05:12 PM
#26
Set me straight if I am wrong but the only number working against me is my payload. As long as I am aware of the weight of my occupants, cargo in the truck, and tongue weight I would be fine as long as I stay under my top limit. As many folks have mentioned already, I need to make a trip to the scales to see where I come in.
04-10-2016, 05:13 PM
#27
You got it!
2016 Sabre 36QBOK
04-10-2016, 05:18 PM
#28
2016 Sabre 36QBOK
It is just as careless and stupid to throw out a straw man argument when you know nothing about the particular truck you are talking about.
Sent from my XT1254 using Tapatalk
04-10-2016, 05:21 PM
#29
The truck is irrelevant.
The numbers apply to every vehicle out there.
2016 Sabre 36QBOK
04-10-2016, 05:22 PM
#30
New TT: Towing Capacities/Questions
You must tow with a half ton...
04-10-2016, 05:23 PM
#31
As do the axle ratings which IIRC is an older standard.
04-10-2016, 07:03 PM
#32
And extremely capable of it. I tow within my vehicle limits and don't need a 1ton dually to drive safely.
04-10-2016, 10:26 PM
#33
Ouch, 1100 lb payload...
I thought the loaded Ram 1500s had the lowest at around 1200. Learn something new every day.
My payload is 1590, but I have a "mid-grade" Ram and I have to be careful about loading my truck.
Your truck should still pull it well, but if you have an accident and there are lawyers involved you could be in trouble FWIW.
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
04-11-2016, 02:44 PM
#34
Full propane tanks are included in the dry weight for that new of unit.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
04-11-2016, 06:31 PM
#35
Can I Hall It
Pal 216 sums it up - look at the door pillar! Notice his Pay Load 1193, that includes driver, occupants, what's in the bed and tongue weight (LDH doesn't matter - it just transfers weight somewhere else), so subtract your tongue weight 793 and he could carry 400 of other stuff. This is a great example of what happens with quad cabs (where do you put the kids?). By the way the GVW 7,200 if you go to a CAT scale be sure to have your hitch on board, it is payload. The difference between CAT and 7,200 is your actual payload.
DJsFolly
04-11-2016, 06:40 PM
#36
That payload number is by far the most shocking part. I had an almost identical 2012, except 2WD, and it had a CCC of 1,79- (don't remember the exact number).
2014 Surveyor SC321BHTS SOLD
2016 Nissan Titan XD SL4x4 Cummins SOLD
2007 Sierra Sport M26FSFB Toy Hauler
2002 Ford F250 7.3l 4x4
