Old 04-10-2016, 05:23 PM   #31
As do the axle ratings which IIRC is an older standard.
Sent from my XT1254 using Tapatalk
madmaxmutt is offline   Reply With Quote
Old 04-10-2016, 07:03 PM   #32
Originally Posted by Kenny kustom View Post
You must tow with a half ton...
And extremely capable of it. I tow within my vehicle limits and don't need a 1ton dually to drive safely.
Old 04-10-2016, 10:26 PM   #33
m2kamp's Avatar
Ouch, 1100 lb payload...
I thought the loaded Ram 1500s had the lowest at around 1200. Learn something new every day.
My payload is 1590, but I have a "mid-grade" Ram and I have to be careful about loading my truck.
Your truck should still pull it well, but if you have an accident and there are lawyers involved you could be in trouble FWIW.
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 04-11-2016, 02:44 PM   #34
CaptnJohn's Avatar
Full propane tanks are included in the dry weight for that new of unit.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-11-2016, 06:31 PM   #35
Can I Hall It
Pal 216 sums it up - look at the door pillar! Notice his Pay Load 1193, that includes driver, occupants, what's in the bed and tongue weight (LDH doesn't matter - it just transfers weight somewhere else), so subtract your tongue weight 793 and he could carry 400 of other stuff. This is a great example of what happens with quad cabs (where do you put the kids?). By the way the GVW 7,200 if you go to a CAT scale be sure to have your hitch on board, it is payload. The difference between CAT and 7,200 is your actual payload.
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 04-11-2016, 06:40 PM   #36
fx2
That payload number is by far the most shocking part. I had an almost identical 2012, except 2WD, and it had a CCC of 1,79- (don't remember the exact number).
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
towing
