Old 08-26-2013, 10:54 PM   #1
Travel Trailer Newb
Boxerglocker's Avatar
New TT, what WDH to get?
Need some help here folks… new TT 2014 Surveyor Cadet, dry weight is 3789 lbs. I’m estimating 4500 Lbs total with propane, batteries, spare tire, awning and full water tank. So roughly 5000 Lbs/ 500 TW on average loaded with our normal traveling equipment.
My TV is a 2009 Ford F150 SCREW 5.4L 4x4 with factory tow package and Hopkins “Agility” brake controller. The profile as is sits pretty level to the eye. However, I know I’m running max on the weight carrying capacity of the hitch of 5000/500. I've been reading a lot on the Reese WDH’s and thinking I'll be going to go that route based on reviews and price. The problem is I'm racking my brains on how high of a rating I should go to.
Any insight on how I should evaluate my particular needs? What would you experienced guys recommend? 6000/600 or higher? How high is too high? What Reese set-up with sway control would you recommend? Should I even bother getting one yet? Run it as is and see how it goes?
Thanks for the help.
2014 Surveyor Cadet SC189
2013 Ford F150 XLT 4x4 Supercrew 3.5L "Ecoboost"
Boxerglocker is offline   Reply With Quote
Old 08-27-2013, 02:41 PM   #2
Travel Trailer Newb
No longer need input decided to go with an Andersen WD hitch system.
Old 09-03-2013, 02:46 PM   #3
thebrakeman's Avatar
Wow, that was a fast convert.
Watch your coupler for damage over time. It's a new design, and that is a concern.
thebrakeman is offline   Reply With Quote
Old 09-03-2013, 03:09 PM   #4
I posted this once before but here it is again. I am very pleased with my Andersen Hitch. It looks like only one coupler has a problem with the Andersen Hitch.
2012 Coachmen Freedom Express Deep Slide 270FLDS
2012 Ford F150 Eco Boost
Andersen WDH
uncle46 is offline   Reply With Quote
Old 09-04-2013, 04:54 PM   #5
That's OK. I love my well-proven Equal-i-zer, but I still watch it for problems.
Anderson is not yet proven by time. It's worth watching, in case issues pop up, or other couplers are shown to be sensitive.
