Old 04-13-2013, 05:37 PM   #1
Biscuit's Avatar
New Wheel Bearings on TV
Just had to replace the wheel bearings on my 2006 Silverado 2500HD FWD. 77,000 miles.
They replace the whole hub assembly on both sides, $275 each.
2006 Chevy Silverado 2500HD
2012 Rockwood 2902SS
Biscuit is offline   Reply With Quote
Old 04-13-2013, 05:59 PM   #2
AquaMan's Avatar
Had to replace one on my 2006 2500 before I traded it in, had around 60k on it. Can't remember how much I paid, but it wasn't cheap.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-13-2013, 08:23 PM   #3
wyo700's Avatar
That's the only way with these new trucks they are all the same. It's sealed bearing. Did you replace them yourself? There not bad to change if you have the tools.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-13-2013, 08:29 PM   #4
TURBS's Avatar
Replaced both of mine on my 2005 silverado at 170,000
Hub asy. is the only way you can get it.
Old 04-13-2013, 08:35 PM   #5
AquaMan's Avatar
I had never had to replace a bearing in a truck that had under a 100k. That's why I couldn't believe I had a bearing go out at 60k. Actually I haven't owned a truck long enough to get much over 100k in 20 years. I did have a '65 Chevy with 350,000 on original untouched 250 straight 6.
Old 04-13-2013, 08:36 PM   #6
Not cheap on the Dodge 2500/3500's either it's a fairly easy job to do on these Rams if it's not siezed in the spindle. I just did my U joints in the front axles what a PITA getting them out of the axle/hub yokes.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 04-13-2013, 08:38 PM   #7
TURBS's Avatar
I traded it at 200,000 and other than normal maintenance I put very few parts in it.
wheel bearings
front brakes
knock sensors "under the intake"
water pump
shocks
Old 04-13-2013, 09:05 PM   #8
AquaMan's Avatar
wheel bearings
front brakes
water pump
shocks
I use to wrench on everything, now I can barely remember where the hood release is. I still like to do some tweeking on boat motors though, not nearly as crowded.
Old 04-13-2013, 09:09 PM   #9
What ever happened to vehicles one could work on, and didn't have to pay 2 or 3 hundred bucks for the most simple part.
$275 for a bearing?
C'mon man!
bakken is offline   Reply With Quote
Old 04-13-2013, 09:41 PM   #10
Wanna Be Camper
SaskCampers's Avatar
Fords and Dodges can still be converted to regular tapered bearing manual locking hubs for abt 2k (Bigger gain on the Dodge given they run the front end full time vs the auto/manua hubs on the Fords). Guys have also modified the unit bearings on the Dodge HD's to have a grease zerk and seem to make them last longer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
