03-28-2017, 09:17 PM
#61
Originally Posted by lbrjet
Link plate is over tightened. Just leave it alone and check those nuts every 500 miles or so because they can loosen. Be careful not to bend it any further.
That's crazy as I used 60-75lbs of torque (can't recall the exact torque) and never over torqued it and only did those bolts once. Should I swap the two to see if they bend back?
Seems flimsy to bend that easy. TT is a good bit under 10k
03-28-2017, 09:43 PM
#62
Contact the company. See what they think. Let us know what the response is. It is a fair question. My stuff did not bend.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
03-28-2017, 09:46 PM
#63
Yes sir, just sent them a message. Those plates look tough. Surprised they bowed. I see pics online where it's obvious why it bowed but my kobalt torque wrench is brand new so it has to be right where it needs to be
03-28-2017, 10:17 PM
#64
I have not used an Equal-iz-er in several years, but I am pretty sure the link plates are 65 ft lbs max. 75 ft lbs is too much for those plates. That is more likely the L bracket torque setting.
03-28-2017, 10:18 PM
#65
Yea , I don't recall but it was by the book
03-28-2017, 10:22 PM
#66
I would read that book again, because I think you might have confused the wording. Those plates will bend at 75 ft lbs pulling around the top/bottom of the frame. The L bracket is a flat plate against a flat plate, that can handle the higher torque.
My Andersen brackets are far more substantial and they are maxed out at 90 ft lbs.
03-28-2017, 10:26 PM
#67
Yes, page 14. 65 lbs. I followed the book to a T. No guessing whatsoever. 75 is the l bracket
So will it be a problem? I'm going to talk to manufacturer and if they don't do anything, should I replace or they ok? Reverse them with other side inside plate to straighten or just go with it? Will it be dangerous?
03-28-2017, 10:31 PM
#68
They're 12 buck so not worried. I'll replace
03-28-2017, 10:32 PM
#69
Not sure, but they are pretty good company. My bet is they will send you a new one. If not, it is likely the second least expensive part of that hitch besides the bolts.
03-28-2017, 10:34 PM
#70
Right on, I'll hold off on ordering
03-29-2017, 08:32 AM
#71
I'm not really sure if I'm asking this right but did you tighten the top really snug then the bottom, or vice versa? It would be pretty easy to bend the plate if you did. Finger tight one then the other and go back and fourth between the two keep equal pressure on both during the process.
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
03-29-2017, 09:01 AM
#72
Yea, I thought I was methodical. Finger tight then a couple of turns with the socket on one then the other. Back and forth until torque wrench clicked
03-29-2017, 09:17 AM
#73
They said to flip them and see if it corrects the bow. Call em back if not and we'll go from there. Guess I'll try it and just buy more if I need to.
03-29-2017, 09:39 AM
#74
Ok, I bent a set once by not doing it this way. Experience is a great teacher.
2017 Salem 27RKSS
03-29-2017, 10:21 AM
#75
The best! Always learn from breaking something!
04-19-2017, 10:15 PM
#76
Thinking about moving the bars up a notch to see how much more weight I can get off the truck. Is there a point where you get too much off? I'm guessing yea. Right now the sway bars are dang near level along with the trailer tongue. Is that pretty much where you want to be?
Thanks again!
04-20-2017, 06:08 AM
#77
Who Dares, Wins
Mine are straight. You want to follow the directions, but once setup the truck should return to almost the same ride height as without the trailer and WD hooked up. You can take off too much off the front end. I am sure you COULD do the same in the rear but that, I can imagine, could be hard.
2015 Chevy HD D-Max
2022 Impression 315MB
04-20-2017, 08:09 AM
#78
Gotcha, probably best to leave well enough alone with everything being level. Always looking for an improvement where I can get one. Have a good day all!
04-22-2017, 04:04 PM
#79
Just finished setting mine up. Looks straight to my eye. . Got it back to within 1/8" which I think is good enough for me.
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
04-22-2017, 07:28 PM
#80
Nice trailer! Ford is cool too I suppose :-)
