Old 08-10-2014, 09:48 AM   #1
Newbie towing issues
My wife and I just retired and purchased our first camper. We have upcoming plans to spend a few weeks in the western states. Maybe I'm new at this, but I am not happy with how it tows. We get a lot of fore-to-aft pitching. I feel like we are bobbing along in a rowboat, pitching front to back. If the road is even a little rough it feels like the camper is intermittently pushing us along. Windjammer 2809w trailer, Equalizer 1000 lbs. hitch, Ecco Boost F-150 with towing package. We don't carry much in the way of stuff, 6200 dry weight with about 700lbs on the tongue.
Too much on the tongue? Too little? Should I adjust the hitch to add weight to the tongue?
Thanks in advance!
Rhoogenakker is offline   Reply With Quote
Old 08-10-2014, 09:53 AM   #2
I'm no expert so hopefully someone else will pipe in too, but from what I have heard, the "porpoise " effect usually comes from too much weight put on the truck from the load levelers. Try a link or two less in the chains and do a test pull.
kappel15 is offline   Reply With Quote
Old 08-10-2014, 10:06 AM   #3
Not much Info to work with,year & Miles on truck?,Tire type on truck? How much preload on T-bars? Fluid in Tanks of unit? Full/half? Front to back jerking can be lots of diff.things! Call a friend with a diff.truck to give it a test pull. Youroo!!
Old 08-10-2014, 10:46 AM   #4
Truck is a 2013 f150 with about 6500 miles on it. The leveler are sett at their lowest setting. I swapped out original tires with 8 ply truck tires. Tanks are all empty. My neighbor has a trailer about the same size and weight. The receiver height on his GMC 2500 is close to the same height as my truck so we tried my trailer and his truck. Same effect but not as severe. His truck is obviously heavier.
Old 08-10-2014, 11:24 AM   #5
When hooked up to trailer, have you measured fender wells front and back to see if they are the same height? This is what you are trying for when hooking up load levelers.
Old 08-10-2014, 01:01 PM   #6
You know, I checked that before. I just went and I rechecked to be sure.
Truck only: 38 fr. 40 rear
Truck & camper 38.5 fr and 38 rear
Truck & camper- bars attached 38 fr and 38 rear.
Old 08-10-2014, 01:24 PM   #7
Whoops. Truck and camper was 37 rear.
Old 08-10-2014, 01:33 PM   #8
Your readings seem strange. It looks like that when you added the bars you did not transfer any weight from rear to the front. I was suprised your front only rose 1/2 inch.
Check out the install instructions below..
http://www.equalizerhitch.com/pdf/eq...anual_0111.pdf
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-10-2014, 01:36 PM   #9
USN/LAPD (Retired)
Safari-Rick's Avatar
Yes to everything all the guys said.. But, another thing to consider is ensuring that your fresh water tank has water in it. This helps stabilize the trailer and if your weight distribution bars can be adjusted...do so. Too tight is not right and too loose wobbles you like a goose....
That's my 2 cents )
Safari-Rick is offline   Reply With Quote
Old 08-10-2014, 02:03 PM   #10
Batts-toy's Avatar
Another member recently had the same problem, turns out his hitch ball was to small for the TT hitch allowing a lot of slop in the connection, just something to double check.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
newbie, towing
