Old 02-02-2014, 11:54 AM   #1
Newbie towing question
We just purchased a 2014 salem 30qbss and i am towing with a 2004 f 150.
I am wondering if either towing gear setup is better then the other. The dealer sells the round bar style, but people are telling me that the "reese" style square bars are better. Any opinions???? I will also be running dual cam sway. Any info is appreciated. Thanks in advance.
Jamesandtara is offline   Reply With Quote
Old 02-02-2014, 03:58 PM   #2
bikendan's Avatar
depending on how your Ford is spec'd, you may be over its limits.
that trailer is very tongue heavy and when the truck and trailer are loaded, may be too heavy for the truck.
you need to post the truck's engine size, cab size, bed size, rear end ratio, 4x2 or 4x4 and payload capacity.
either way, figuring you have a big family, that's why you bought the bunkhouse, you will be close or over the truck's capacity.
and you better make sure you get a real good WDH with built-in sway control with a 33' TT. like a Equalizer or Reese Dual-Cam. or if you have the money, a Hensley or ProPride.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-02-2014, 04:21 PM   #3
Its a FX4 supercrew with a 5.4 with 3.73 gears. Weight is not an issue but honestly I am a little worried about the tongue weight..
Old 02-02-2014, 05:04 PM   #4
Platokidd's Avatar
980 lbs of tongue weight on the unit I googled, bet is closer to 1200 lbs. when said n done.
To me it seems like a lot tongue weight for a 6575 lbs unit. Maybe too much tongue weight for 1/2 ton imo.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 02-02-2014, 05:05 PM   #5
Looking online, it looks like your trailer's max weight is about 11,000 lbs (about 6,500 lbs dry + 4,500 lb cargo). That would translate to at LEAST 1,100 lbs on the tongue, probably more. A couple F-150's in the 2009 trailer towing guide (oldest one I've got) went up to 11,200 lbs (this would be without any passengers or stuff in the truck), but most did not. No tongue limits are given in the guide. But I agree with Bikendan, you're most likely over the limits already. Would need to know more, like bed length, tow package, etc.
Bottom line: Read your owners manual. It should tell you the max tongue weight, as well as all the other weights you need to worry about, for however your truck is set up.
I hope your salesman didn't tell you "Oh, this is 1/2 ton towable!" (That's the biggest lie in the RV salesman's repertoire!)
2011 Traverse LT, 3.6L, FWD
Old 02-02-2014, 05:11 PM   #6
Would you guys recommend air bags??
Old 02-02-2014, 05:11 PM   #7
According to Ford that year model had a max towing capacity of 9,500 lbs; and that probably was not for the FX4 style.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 02-02-2014, 05:15 PM   #8
Yea from what I found I am rated for 9,500 towing. Honestly never checked tongue weight.
Old 02-02-2014, 05:18 PM   #9
Your truck's 10 years old. I think you just found an excuse for a new one!
Old 02-02-2014, 06:27 PM   #10
TeresaInCAL
TeresaInCAL's Avatar
Dude, you're going to need a f250 for that new trailer.
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
newbie, towing
