Old 01-17-2019, 05:40 PM   #1
SecretSquirrel's Avatar
Newer Ford options
Have the new F350 in the signature. Supposed to have the heated mirrors. Be darned if I can find the switch for them per the owner's manual. Supposed to be able to turn then off/on via the Sync3 system too, nothing there. I'm thinking they may be fully automatic but I'd prefer manual option and Ford ought to at least update the manual if that's the case. Also, is there a way to force a regen or do you have to wait for a message in order to do that?
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 01-17-2019, 05:45 PM   #2
SlowrideHD's Avatar
Mine come on whenever I turn on the rear window defroster strips.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 01-17-2019, 06:09 PM   #3
SailorSam20500's Avatar
My copy of the owners manual says:
HEATED EXTERIOR MIRRORS (If Equipped) When you switch the heated rear window on, the heated exterior mirrors turn on.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 01-17-2019, 06:37 PM   #4
Same as my Toyota.......who'da thunk? ....
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 01-17-2019, 06:56 PM   #5
Now a "Top Member"
EdJunior's Avatar
They already answered the heated mirror part above, and there is supposed to be a way to start a manual regen. I'm not sure if it's part of one of the trim/packages, or if there is another way to do it. I saw something on it, but can't remember or find it. I'm betting if you search on Youtube, you can find it though.
I have the F-250 XLT version, nicely equipped. They are some nice trucks. Congratulations.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - Still too new
Old 01-18-2019, 03:56 PM   #6
Thanks for all replies everyone! My old f250 the side mirror heaters just came on whenever you selected the regular heat to defrost. Didn't have a rear window defroster like the new one. Owners manual is very misleading on this. Makes me wonder what else is wrong in there.
Crusader 337QBH
Old 01-18-2019, 04:11 PM   #7
My owners manual says the same as SailorSam's... not sure what is misleading in that statement?
Does your say something differently?
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 01-21-2019, 08:58 AM   #8
Your dealer may be able to reprogram the truck PCM and instrument cluster, so the driver can force a manual regen. The older models required the base instrument cluster.
sbergherr is offline   Reply With Quote
Old 01-21-2019, 09:09 AM   #9
Assistant TP Supervisor
B and B's Avatar
I am not sure why you want a manual Regen? I have had two diesel trucks and they look after it themselves.
Old 01-21-2019, 09:57 AM   #10
It's just what my owner's manual say you should be able to do. When I can I'll try to post a pic of it.
Crusader 337QBH
ford
