Old 02-05-2013, 05:56 PM   #11
Steve09's Avatar
Man, you all are making me happy so far,I can't wait to hook up to it. I have heard about the egr, head gasket problems to.Looks like it was taking in to the dealer for all the regular maintance though. but you never know. I have change all the filters and oil again to. They all looked good,, I put ford filters back in along with ford 15w-40,,thought I might go with the Rotella ? Thanks for all the imput.
2009 Salem La 292FKDS--7600 lbs
2006 F250 fx4 Ext Cab,Diesel
(sold)2004 F-150 5.4 Auto FX4 3.73 Gears with Factory Tow Pkg, 36 Gal Tank, 96,000 miles ,Equalizer Hitch 10000 lb Bars ,MBRP 3in Cat-Back Exhaust SI/SO
24 Days in 09, 35 Days in 10, 24 Days in 11,,23 Days camped so far in 12, 22 Days Camped in 13,,6 Days Camped in 14
Steve09 is offline   Reply With Quote
Old 02-05-2013, 08:09 PM   #12
Oklahoma Proud
MillerTime's Avatar
Yes the 6.0 will run circles around a 7.3 and much better towing than gas!
- I've always used rotela in all my equipment and trucks- so far so good, probably use it for as long as I'm around!
Old 02-05-2013, 08:44 PM   #13
phat phrog stunt crew
rotella is all i have ever used, both when otr driving and my daily driver duramax. if you have to get new head gaskets at some point (way in the future lets hope) , i would suggest a good set of head studs from companies like arp.
dwaynerz is offline   Reply With Quote
Old 02-05-2013, 09:54 PM   #14
Steve09's Avatar
Ok ,,Thanks alot,,,Happy Camping.
Old 02-05-2013, 10:09 PM   #15
Sgt. Schultz's Avatar
Steve you may find the the following links of value: 6.0 Powerstroke Common Issues and Problems & http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf We ran across them when a friend was looking at an 06 F250 Lariat
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 02-05-2013, 11:43 PM   #16
jimh's Avatar
i have the 7.3 and a 36' cardinal. pulled to ashville from Marlyn a few years ago. only problem i had was before ashville when i got behind a big truck and couldn't get around him w/o impeding traffic. if i can do it, i wouldn't expect u to have any problems with the 6.0
one thing i would add is that the 2002 put a gold antifreeze in it that is to be replaced at 100k. look in ur ford manual and see what they say. that tends to be very important.
mine had abt 40k on it when i did that trip. i now have 150k and it is still strong. my engine has not been chipped.
the dealer has changed my oil every sense 50k. they use shell rotella 15-40. they charge $50 for an oil change on the diesel.
jimh is offline   Reply With Quote
Old 02-06-2013, 12:33 AM   #17
Taranwanderer's Avatar
Steve-- I have the exact same camper as you and pulling it with my '11 diesel Ram has been a total pleasure, even with the freshwater tank filled up at home and an 80 mile trip, up and down NEPA interstate hills--its still smilin' time! Have fun.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 02-06-2013, 07:20 AM   #18
Trailer Trash
The 6.0L is a excellent engine...........In a school bus. Yup, that's were it originated from International. Once put in a pickup truck, they had heat issues as the nose of a pickup truck is much smaller than a school bus, panel van, etc.
School buses are well maintained, not beat on, not chipped, etc. If you drive and treat your 6.0L pickup like a fleet maintained school bus, they actually do well. Leave it stock, don't beat on it, and do the factory maintenance schedule.
EGR valve and solenoid need to be cleaned/replaced.
OIL Cooler and EGR cooler - upgrade this to the TSB Ford has.
OIL must be kept fresh/clean - hi pressure oil rail injectors need this
Sticky injectors - Hot Shot's Secret Stiction Eliminator fixes them
Head bolts are VERY long on this engine and stretch over time causing heads to lift and blow out head gasket. Heat and pressure was cause. Again, heat is the weak point in this engine. Watch coolant level in tan bottle/tank. If it keeps loosing antifreeze.........that is your clue to impending problems. Replace the cheap ass Ford cap on the coolant bottle. That part almost always fails and is the start to overheat situation. Buy this 5 dollar part today!
Buy Stant Cap Coolant Bottle 10238 at Advance Auto Parts
Good TSB and other tech info here
6.0 PowerStroke bulletins
6.0L Diesel: ..................Tech Folder.............. - Ford Truck Enthusiasts Forums
joelek is offline   Reply With Quote
Old 02-06-2013, 07:32 AM   #19
abjb's Avatar
If you haven't already then visit
http://www.ford-trucks.com/forums/forum107/
We never had any problems with our 6.0 (wish it was in our MH).
There are LOTS of upgrades for your F250.
air bags
harpoon my favorite upgrade FREE http://www.ford-trucks.com/forums/646820-harpooned-the-fuel-tank-this-weekend.html#post5070375
By-pass Coolant filter the #1 or 2 reason for head-gasket failure in the 6.0
NO chip/programmer the #1 or 2 reason for head-gasket failure in the 6.0
Enjoy, we certainly did
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 02-06-2013, 09:12 AM   #20
5er_tom's Avatar
When I was in the market for a tow vehicle, I did a lot of research. I was a little concerned about the additional cost of the diesel vs gas. The Ford gas V8 has about 400 ft #'s of torque. The diesel has 800 ft #'s of torque. There is really no decision here. The diesel is the only way to go. As stated above, it tows the 5th wheel easily, even in the mountains. I'll never go with a gas engine again.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
