Old 12-22-2015, 07:59 PM   #1
Newer TV Opinion
Looking at upgrading my current tv to a dually. I've seen a few that I'm interested in, but the have, our have had a gooseneck ball in the bed. Seeing as I have to put 5th rails in the bed, is there a frame/structure issue by drilling more holes in the frame by doing this? Thanks!
Wumba is offline   Reply With Quote
Old 12-22-2015, 08:20 PM   #2
mud yapster's Avatar
My new 1 Ton dually came with a 5th wheel set up in the bed. I did have to spend the extra cash on their adapter that the 5th wheen hitch sits on in the bed. Nice system though and easy to take out when ever you need to haul plywood or whatever else in the bed. I like it.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 12-23-2015, 02:34 PM   #3
Not sure what you have, but if it's a Dodge they make a clamp on frame kit for mounting rails in bed, eliminating requirements to drill. As far as drilling frame, it's done a lot, but if it already has holes drilled just be aware if you drill more holes in the immediate vicinity you will weaken the frame.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 12-23-2015, 06:06 PM   #4
Major's Avatar
Ford also has the Reese (or Reese compatible) puck mount option for the Super Duty that has both the pucks for the 5er hitch and a gooseneck drop-in as well. I have it on my F-350 and love it.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
