Old 07-10-2016, 02:17 PM   #1
Nissan Frontier crew cab v6
Would anyone advice to 4200 pounds with this Nissan?
greatblue7 is offline   Reply With Quote
Old 07-10-2016, 03:43 PM   #2
bikendan's Avatar
Which spec is 4200lbs?
Dry weight, GVWR, GVWR, CCC, UVW, Towing capacity ?
Equalizer WDH
Old 07-10-2016, 03:46 PM   #3
4200# dry weight thanks.
Old 07-10-2016, 04:44 PM   #4
DavidBo's Avatar
Check out this post about a recent adventure I had towing a new 2104S with my Frontier crew cab. The trailer has a dry weight of about 4150 pounds, which is well under the 6300 pd towing limitation.
BUT!!!
Search this forum and you'll see tons of info concerning a truck's real towing limitation. The biggest concern is exceeding the combined gross vehicle weight of your Nissan. Dry weights can be very misguiding concerning your TV's ability to pull. Frontal area and the TV's wheelbase are also factors.
I towed my trailer about 150 miles or so, mostly freeway, bringing it home from the dealer. I was as light as possible...just me, a tank of gas and a few bottles of water* in the truck and the only additions to the Rockwood were propane and a house battery. The truck performed fine, but I wouldn't want to use it on any major trips. Cargo loading is very limited and forget about anything in the tanks.
My experiences, good luck with yours !
*also a small bag of Doritos. Gotta carb up for the drive!
DavidBo is offline   Reply With Quote
Old 07-11-2016, 04:47 AM   #5
Mat
Fronty owner aswell and proud of it! I tow a 23LB (3750lbs, dry) and it handles and pull like a charm at speed limit. I got a well adjusted WDH, swaybar, brake control, extended mirrors and just install some Firestone air bags to smooth the ride and trust me it does, especially if you got off road package. As for MPG I get between 8-12mpg which I think is reasonable for pulling a wall...
Mat is offline   Reply With Quote
Old 07-11-2016, 08:15 AM   #6
Mat How Far
Thanks for your reply. How far do you usually travel?
Old 07-11-2016, 11:15 AM   #7
Mat
It's my first year with the 23LB, for now the farthest I did was 300km but we are planning a trip down from Ontario to Florida next January!
Old 07-11-2016, 06:44 PM   #8
Newbie
Greatblue - towed a 2104s (4092 dry weight) about 6k miles my first year. It did the job and did it well about 75 percent of the time. But battling headwinds and summer heat in the plains of Oklahoma and Texas while heading to Colorado wore me out. Truck would run between 3 and 5k in these type of conditions and a/c would not keep us cool. I had an equalizer hitch installed so sway was never an issue. I traded in for a used F150 Ecoboost this year and could not be happier. I think if you only plan on making short trips around your local area the Nissan will do just fine. But as you have probably already read in this forum, you can never have too much truck. Good luck on your decision. You can always trade up to a bigger Tow vehicle later on if the Nissan doesn't cut it.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
Old 07-11-2016, 07:35 PM   #9
Okiecowboy - thanks for the advice. What size ecoboost do you have and how many miles were on your Ford when you bought it. I have been looking at cars.com today for an F150. We will be travelling many long trips over 900 miles and I want to go to Alaska, Wyoming and Oregon. Have visited 42 states and would like to see the rest.
Old 07-11-2016, 07:50 PM   #10
Newbie
Wow, you plan on traveling some miles! In that case , I could not recommend the Nissan. My F150 is a 2013 EB 3.5 liter. It had 33k miles on it, and I ended paying $33k for it. It is so much quieter and more comfortable than the Frontier, we love it. And the 36 gallon tank is sure nice. Since I wanted a used Ford, I don't know much about the 2.7 liter, as they were introduced in 2015. Probably a little better fuel economy and not quite as much power. Hope you enjoy all your travels. Sounds like some great times ahead.
2015 Rockwood 2104S
