Old 06-11-2016, 10:01 PM   #1
john5646's Avatar
Nissan Titan, just added tranny cooler
Installed mishimoto trans cooler today unit comes with electric fan. Don't be misled by the name, this company is in New Castle DE. Anyway very happy with this cooler, I chose to install in addition to factory cooler, so this is mounted as the last cooler before oil returns to Transmition. Posting since I only learned of these recently ( with fans on them that is ) and wanted to share...Click image for larger version
Name:	ImageUploadedByForest River Forums1465700416.980226.jpg
ID:	110867Click image for larger version
Name:	ImageUploadedByForest River Forums1465700434.039474.jpg
ID:	110868Click image for larger version
Name:	ImageUploadedByForest River Forums1465700450.716082.jpg
ID:	110870Click image for larger version
Name:	ImageUploadedByForest River Forums1465700466.196615.jpg
ID:	110872Click image for larger version
Name:	ImageUploadedByForest River Forums1465700480.986611.jpg
ID:	110873Click image for larger version
Name:	ImageUploadedByForest River Forums1465700498.015495.jpg
john5646 is offline   Reply With Quote
Old 06-11-2016, 10:20 PM   #2
I go RV'ing not Camping
jgourlie's Avatar
Very cool...how is the fan controlled?
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-12-2016, 05:31 AM   #3
john5646's Avatar
I wired a toggle switch. Figured I'll likely only need to use while towing. And I also thought it would be nice to let it run for a few minutes after shutting truck down after towing and or on hot days, just to allow some distribution of air over hot engine. It's my understanding that A thermostatically controlled the system is available but I elected for the manual system, for these reasons above.
Old 06-12-2016, 02:49 PM   #4
jgourlie's Avatar
I researched this product a bit after you posted, it seems like great idea. I have only towed with my truck once and I am not sure if I will need more cooling, but if I do I'm getting this product for sure
Old 06-15-2016, 08:25 PM   #5
Hi Jgourlie. I did transmissions for 31 years. You will not know if you need a cooler unless you have a trans temp gauge, your friendly neigbourhood trans repair shop suggests it during the overhaul, or the engine starts to overheat because the engine radiator can't disipate the engine and transmission heat. Add the cooler now and save yourself the grief. Transmission parts last longer at 150F than at engine temp (195F), even though engines prefer 195.
perrogie is offline   Reply With Quote
