Old 01-11-2015, 02:40 PM   #11
mike.t's Avatar
Good luck in your travels.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 01-11-2015, 07:11 PM   #12
If anyone is towing a 9500lb 5er with a Titan they're overloaded. Nothing new in the 1/2 ton-5er world.
goduc is offline   Reply With Quote
Old 01-11-2015, 07:17 PM   #13
Done with this
They are unveiling the new Titan tomorrow with Cummins power. Not sure of the weight capabilities, but it should be in line with the new Fords. It should shake things up a good bit.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 01-11-2015, 07:48 PM   #14
Done with this
Old 01-11-2015, 07:56 PM   #15
Flagstaffer06's Avatar
Someone a few years back did it, not sure for how long or how well it worked.
Finally got our 8265s
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 01-11-2015, 08:08 PM   #16
Done with this
I can almost guarantee he was overweight on his pin weight. There is no way to get some weight on the front axle as short as the bed is on a Titan. The weight will always be behind the axle. Air bags aren't the magical cure all...They help but, increase nothing...
Old 01-11-2015, 08:49 PM   #17
Cyber Phrenologist
Radio's Avatar
Half ton trucks are limited to only a very few 5'ers they can safely tow. Your selection will be limited. The major problem I see is the 5.5ft bed. Ford recommends NOT towing 5'ers with their 5.5ft beds that come with the full 4 door crew cab.
The rig in the sig has a 6.5ft bed, 850 pound on the pin, 7800 pound trailer, loaded, per the scales. Reese slider hitch. And a dent in the cab.
And any 1/2 ton should have upgraded tranny coolers in addition to the factory tow package cooler. And a tranny temp gauge is a good idea, too. IMHO.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 01-11-2015, 08:56 PM   #18
Fulltime family RVer
[QUOTE=Radio;762938]The rig in the sig has a 6.5ft bed, 850 pound on the pin, 7800 pound trailer, loaded, per the scales. Reese slider hitch. And a dent in the cab./QUOTE]
Sorry to chuckle, but which came first? The dent or the slider?
ependydad is online now   Reply With Quote
Old 01-11-2015, 09:12 PM   #19
Cyber Phrenologist
Radio's Avatar
I don't mind the chuckle. This is a teaching moment to any who reads this.
The dent is there as a monument to my laziness and complacency. You see I found out that if you are pulling forward in a tight turn on flat level ground the trailer will clear the cab.
And then I found out if you are turning and backing into an unlevel incline, the trailer will NOT clear the cab.
KU4OJ
Old 01-11-2015, 09:15 PM   #20
I have a similar dent under the side of my camper- I found that if you screw up parking so bad that you're headed off of the pad and your wife tells you not to backup, don't talk her into it. I went off that pad and sunk like 9" into the grass!
fifth wheel, towing, wheel
