Old 07-15-2016, 11:46 PM   #11
There is a junction box under the trailer. Look at the frame just behind the battery box on the drivers side.
The ground wire comes from this junction box. There should be 2 of them, because one of them needs to go forward to provide a ground for the front clearance lights. (You'll see a power and a ground wire in your front storage for the front clearance lights).
The rear ground runs back on the drivers side of the frame and comes up into the rear storage compartment on the drivers side. The power wires for the brakes and tail lights should also do the same.
If you have trouble figuring out which wires are ground, remove the cover of the junction box. The largest wire nut on the largest number of wires should be the ground. It will be one of those "largest number of wires."
Here's an overall wiring diagram of the circuit:
http://www.actionoutboards.com/trailerwiringdiagram.pdf
The one problem with this diagram is that it doesn't show the ground wiring; each lights ground wire is assumed to be attached to the metal frame of the trailer. This is basically used on boat trailers, but RV's actually wire the grounds together and run them back to the junction box. It doesn't matter which lights ground hooks into the ground wire in which order, so long as it does. The entire ground wire is "electrically ground." The problem is that they may hook the grounds of the right tail light and brake light together, do the same to the left tail light/brake, then hook those two grounds together, then tie in the clearance light grounds. So if something came apart, depending on how they did it, it could leave the clearance lights attached to ground, but the tail lights/brakes unattached to ground.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 07-16-2016, 12:26 AM   #12
Originally Posted by jscraig View Post
Hello all. I'm in need of assistance. I have a shamrock 19, and am traveling to florida. I seem to have lost my brake lights and signals. All of the other exterior lights are functioning. I have already replaced the bulbs just to be sure. This did nothing. Any help would be greatly appreciated.
JS: I just read your OP more closely and it sounds like it's ONLY the brake lights that are bad. If your turn signals are working, then you definitely have a tow vehicle (TV) problem. If your turn signals aren't working, that would point to either the tow vehicle (TV) or the 7-pin connector as the most likely culprits, as previous posters have given you info on.
Old 07-16-2016, 08:32 AM   #13
f5moab's Avatar
If the turn signal and brake lights work on the vehicle but not on the trailer, I would just disconnect the 7-pin and check for power to the brake/turn signal wire at the connector. If there is power with the brakes applied and/or turn signals on, then the problem is from the trailers side of the connector through the trailer.
f5moab is offline   Reply With Quote
Old 07-16-2016, 08:43 AM   #14
RSchleder's Avatar
Most issues with 12V lights are a bad ground. However, since some of your lights are working that doesn't sound like it's your problem. Do you use a spray can of Electronic Contact Cleaner ( plastic safe)? I always carry a can and spray both the TV and the trailer plugs and my light problems have disappeared since I started using this a few years ago.
Days camping (2016)----181 days
Days camping (2017) --- 21 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-16-2016, 08:44 AM   #15
There's another trick to do a quick check to see if the trouble is before or after the 7-pin. Since I have trailers that also have 4 pin connections, I have a 7-pin to 4-pin adapter which has indicator lights built into it. If I have a problem (and I have ) I plug it in and see if it lights up (running lights, brakes, turn signals). If it doesn't flash like it is supposed to do , then I start checking the fuses. If you pull multiple trailers, it is easy to have a problem with one and not notice it. Best 11.95 I've spent in a while!!!
Bill
Cooksonthego is offline   Reply With Quote
Old 07-16-2016, 09:32 AM   #16
f5moab's Avatar
I have one of these, which is very over priced, but purchased used from a neighbor at his garage sale, who sold his trailer.
But most people have a voltmeter (not all, but most), or if in a campground, I bet if you smiled nicely, and walked around, someone would have one you could borrow...maybe.
But your idea is sure a lot less expensive than a dedicated tester.
Old 07-16-2016, 10:25 AM   #17
That looks like a dedicated tester. Mine is a pass thru; my 4-pin trailer plugs into the unit which has lights. That is WAY more hi-tech.
Bill
Old 07-16-2016, 10:34 AM   #18
Bill
Like this one:
https://www.etrailer.com/Wiring/Hopkins/47345.html
Old 07-16-2016, 11:47 AM   #19
Usually Confused Member
emm-dee's Avatar
If just checking for DC voltage thruput this is a cheap way
test light - Walmart.com
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-16-2016, 11:55 AM   #20
f5moab's Avatar
Bill
Yours is also LESS expensive too. I was lucky, I got this in a garage sale, I believe Amazon price is around 35 bucks. Only time I ever used it was when installing a new plug on my Hummer after I tore the old one off.
light, brakes
