Old 12-10-2017, 07:04 PM   #1
No power from truck to lift landing gear
2017 F250 my RV dealer said fuses position 27 and 37 vacant needed to give power to battery when plug connected to truck. Any thoughts?
Jim Wagner is offline   Reply With Quote
Old 12-10-2017, 07:11 PM   #2
Flybob's Avatar
Can't say specifically about your truck, but many tow ready TVs do not have the fuses or relay installed by factory. For many, the fuse and relay are in the glove box when delivered. You should be able to find it in manual. Also if it has a relay, it will only provide power when the TV is on. This is to prevent a drain in the trailer from killing the TV battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-10-2017, 07:29 PM   #3
Ford dealer said my 2017 F-250 came with fuses already installed. Haven't had any issues. My F-150 had to have a fuse installed. Hope this helps.
2017 F-250 6.7 4x4
2016 W&P CB25
2005 HD RoadKing
2002 Yamaha V Star 1100
Cb25 Joe is offline   Reply With Quote
Old 12-10-2017, 09:43 PM   #4
Thanks. Not in glove box will contact dealer.
Old 12-11-2017, 01:04 PM   #5
Wolverine 1945's Avatar
Are you talking about ele jack on the tongue of a TT ???
If so it should it be wired to the TT Battery !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-11-2017, 01:21 PM   #6
Telstar's Avatar
Check the charge circuit at the connecter. If no power take a look at your truck manual to identify the fuse number and location of the trailer charge circuit. Ford undersized that fuse and they often blow if you operate the landing gear with a weak trailer battery. Replace the 20A fuse with a 30A.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 12-11-2017, 01:43 PM   #7
Flybob's Avatar
This may help. Looks like ti has both a fuse and relay.
http://imageresizertool.com/diagram/...l-diagram.html
TST Tire Monitors
2 100W solar panels
Old 12-11-2017, 01:53 PM   #8
I have a 2017 F350. A lot of talk about this on Ford truck forum. Bottom line seems to be you don't need certain fuses, you get power to the plug after stepping on brake pedal for first time after starting engine and trailer connected. I really don't know those fuse positions you are talking about but it appears to come configured correctly from factory as is. I haven't experimented with my fifth wheel yet as it is in storage, but I think you are good to go according to the Ford truck forum.
cub22908 is offline   Reply With Quote
Old 12-11-2017, 02:16 PM   #9
Just a thought. Our Sunseeker on the E450 ford chassis required the ignition to be on to power the trailer 12 volt circuit. Ignition off, no power. I learned that wiring the battery tender on our Jeep toad.
PenJoe is offline   Reply With Quote
Old 12-11-2017, 02:20 PM   #10
Oh_So_New
Location: Currently - Clinton, WA Temp - 1590 Luna Media, Fort Mohave, AZ
^^ X2 ^^
RobertDS is offline   Reply With Quote
lift, power, truck
