Old 06-17-2015, 10:02 PM   #21
Platokidd's Avatar
Originally Posted by hazmat91180 View Post
Given that, how stiff is your ride, that's almost 400lbs extra.
With the 10k I couldn't get enough lift in the rear or weight back on the front axles.
With the 14k my front fenders are back to stk height. Feel its important to get back to stk weight and height up front and no sag in the rear.
The ride..is firm but nothing drastic. I feel an over all improvement in handling performance and my unit sits nice behind my truck.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-17-2015, 10:04 PM   #22
thank you for the clarification, that is helpful. I am going to haul it in two weeks again, with a different weight setup (no mother in law bringing everything and the kitchen sink) and will weigh it and see how I feel it rides.
2016 Rockwood Sig. Ultra Lite 8312SS Platinum
2016 GMC Sierra 3500
Equal-i-zer 10K WDH
Tadi Brothers 9" Wireless 120 degree Rear Cam
2015 Nights Camped: 4
2016 Nights Camped: 8
hazmat91180 is offline   Reply With Quote
Old 06-17-2015, 10:12 PM   #23
Platokidd's Avatar
Your gonna need 3 weigh-ins with truck camper no bars /w bars / and truck only. Then you can crunch the numbers and see just how much weight your shifting around.
nights of camping
Seasonal
Old 06-17-2015, 10:13 PM   #24
Not to side track my own thread but will a weigh station have "patience" for me doing all of that?
Equal-i-zer 10K WDH
Old 06-17-2015, 10:17 PM   #25
Platokidd's Avatar
i had to do the first weigh in and pull off and go inside. Then pull back on and ask for a re-weight , pull off and do it again. The scales here didnt mind , fortunately no one else was using them.
nights of camping
Seasonal
Old 06-18-2015, 01:25 AM   #26
ColoradoRick's Avatar
I found my Equal-I-zer manual and found this:
Noise:
Noise is a normal occurance when towing a trailer and using any weight
distribution or sway control hitch.
In some cases the friction on the L-brackets or sockets also generates
noise. This most commonly occurs during slow, tight turns where the tow
vehicle and trailer are in a twist. This noise is normal and should be expected.
It is an indication that there is friction on the L-bracket and sockets.
Most of the noise will usually subside after a few uses as the hitch breaks in.
Trailer and tow vehicle loading may also influence hitch noise.
Lubricating the socket joint may help reduce this noise, and is part of
the required regular maintenance routine. Lubricating the L-bracket joint is
optional. A better solution is a set of official Equal-i-zer brand Sway Bracket
Jackets™. They quiet the ride without the mess of using a lubricant.
I found them for around $35 for a pair on Amazon (didn't have free shipping) so I'm going to buy them. Product Description:
Equal-i-zer Sway Bracket Jacket
  • The Sway Bracket Jacket was designed to quiet the ride and reduce wear on the L-brackets of your Equal-i-zerŪ hitch. Injection molded from high density polyethelene plastic (HDPE). Each package contains two (2) Sway Bracket Jacket, one for each L-bracket.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 06-20-2015, 10:45 AM   #27
Originally Posted by retiredcamper47 View Post
Those jackets do not work with the new style "L" brackets out of the package with the attached pin. Had to trim mine back to the opening to get the pin to clear to work. They will work with the old style "L" brackets that requires you to insert a pin. Eliminates alot of noise.
Bob
They have a new version of the jackets that fit the new L brackets. I had the same problem as you - bought the old style jackets not realizing they were not the right ones. Called Progress and they advised me to trim the edges but also sent me a new set.
The jackets have not really helped the noise for me. I think my noise is coming from the bar sockets. I'll try a bit of grease there next.
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
tmhudg is offline   Reply With Quote
Old 06-20-2015, 11:05 AM   #28
wyo700's Avatar
That's just the sound of safety. Really don't worry about it. I can care less what other people think especially when I'm not doing anything wrong. They will get over the 5 minutes of noise and if they can't then oh well.
2012 Sandstorm 203SLC
2013 Toyota Tundra Crewmax 5.7
2014 Honda Pioneer 700-4
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 06-20-2015, 01:54 PM   #29
Georgia Frog Rally 2018
aceinspp's Avatar
I don't worry about the noise either tells me the systems is working as designed.My TV and TT sit perfectly level when hooked up. I also have the 14,000 LB Equal-I-zer hitch. Lubing defeats the purpose of sway. My trailer is 35 ft V-light Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-30-2015, 07:39 AM   #30
Because they were really cheap I tried the jackets. So far, reduced noise I would say 75%. Pretty impressed. I can see where a loss of friction would occur though not having metal on metal.
Travelling 100 miles tomorrow with it and will report back and any sense of sway.
Equal-i-zer 10K WDH
equal-i-zer
