Old 05-10-2015, 01:09 PM   #11
Backlash for your 9.25 diff.
Originally Posted by coffeeguy57 View Post
Any gear experts out there?
Got new 4.56 gears Early Late July. Picked it up after they were closed. immediately noticed the howl @45 is called the next day I was told it was normal i just need to drive it and break it in.
100 miles go buy I had to drop it off. They looked at the pattern etc and said you just need to drive it. "sometimes they are just noisy..." they put new oil in and said com back after 1k for fluid dump. They did say they will stand by it however I called to make an appt and mentioned fluid dump and talk about the noise issue...never got a call back.
Dumped my oil on my own, took some pics before I cleaned them up take a look. I have more pics too.
. Corporate 9.25" Rear Axle Used on 1500 and 2500LD Axle Type
Semi-floating, hypoid
Lubricant
API GL 5, SAE 75W-90
Lube Capacity
4.9 pints ( 2.32 L )
Axle Ratio Options
3.21, 3.55, 3.92
Carrier Split
none Differential
Case Clearance
Case Flange Runout
Bearing Preload
0.005 in. ( 0.12 mm )
0.003 in. ( 0.076 mm )
75 ft. lbs. ( 102 N.m )
Ring Gear
Diameter
Backlash
Runout
9.25 in. ( 23.50 cm )
0.005- 0.008 in. ( 0.12- 0.20 mm )
0.005 in. ( 0.127 mm)
Pinion Bearing Preload
Original
New
10-20 in. lbs. ( 1-2 N*m)
15-35 in. lbs ( 2-5 N*m)
Hope this helps. A 'Dial Indicator' is the best way to achieve a true measurement. Best to set it at 0.005 to allow for future wear
EdnKat is offline   Reply With Quote
Old 05-10-2015, 02:11 PM   #12
Left Coast
After market gear sets will have their own set-up markings, and the shop that did the swap probably no longer has original gear set for the markings that were on those. Doesn't look like the hard facing is bad yet, so it might be possible to reset. If you need a different set, go with Richmond brand..... stay away from US Gears (brand name). If the axle housing has a round hole on each side ( the cast part that the side brgs.sit in) just outside where the cover bolts on, a spreader (special tool) should have been used to slightly relieve side brg. pre-load. Other wise, one has to tap (force) the brg. races in. Then , if the backlash is off, need to pull back out, and if there are shims behind brgs. they also need to be added to or subtracted from. the original total thickness should be stayed with, although they can be moved from side to side in any amount to keep pre-load good. IF the ring gear carrier gets changed, then it's a hole new ball-game. Not hard to do, just time consuming and if tech is on commission, look for an hourly guy.
Old 05-10-2015, 02:51 PM   #13
Agree with oldcoot, you need to make the proper adjustments as soon as possible though. The longer you drive it, the more the wear. Sounds like both the pinion depth for the howl noise on acceleration side of ring gear, backlash on the coast side of the ring gear. Check out the bearing preload of the pinion. It should be about 10 to 15 inch pounds of preload. New bearing about 20 to 25 inch pounds. If pinion is loose it will cause both of these concerns.
jimmyt11664 is offline   Reply With Quote
Old 05-10-2015, 03:28 PM   #14
toslow's Avatar
i would put a new set in. it looks like the crown gear is starting to get flashing already.
haven a blast
toslow is offline   Reply With Quote
Old 05-10-2015, 04:22 PM   #15
Crusadernoob's Avatar
Is it me or is the first pic. showing a chipped tooth? None the less, set up was wrong, any noise issue at first drive will never get better after it is driven.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 05-10-2015, 04:28 PM   #16
rattleNsmoke's Avatar
Corporate 9.25 with 4.56'ers....sounds like a lifted Jeep?
rattleNsmoke is online now   Reply With Quote
Old 05-10-2015, 05:00 PM   #17
Iwannacamp's Avatar
If you aren't capable... Find a 4x4 shop. They do it all the time and usually at a discount. I used to have a GM mechanic that did it on the side. I was scared to death of crush sleeve diffs... The last one I did was a Dana 61 and hopefully the last. You need a inch lb torque wrench and a caliper/mic and instructions.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 05-10-2015, 05:35 PM   #18
PhoneDude 8289's Avatar
Takes the right tools and lots of experience to set one up right. I had one done several years ago, tech said it would take about a day. Well he had my truck three days, said he had to order different shims. When I got the truck back not a sound out of the diff, he did a great job. I was charged almost twice the amount for labor but it ran so good that was soon forgotten.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 05-10-2015, 05:49 PM   #19
toslow's Avatar
I've done hundreds of diffs. And mostly all by feel. But every now and then you get a set of gears that no matter how much time you spend. You just can't get a good pattern on.
If the tech was lazy and didn't want to pull the pinions and press the bearing to put put a thicker shim. Then i would be asking for another tech to work on it when if and when they cover under warranty.
Now hear is another question. Was it noisy when you first picked it up.
And if so why would you drive it for thus long without demanding them fix is properly.
haven a blast
Old 05-10-2015, 06:35 PM   #20
Yes!! It was noisy when I first picked it up. I called the next day(first post). You can demand some one do something all you want doesn't mean they will do it..I kept getting the line that it was set up right and high gear ratios are just noisy sometimes. "just turn the radio up" lol.
This is why I posted get some opinions, now i will go to another shop and ask them..Then I will go back loaded with some ammunition to make my case that they replace the gears or at the very least change the setup. They will either do it.. or they wont. We will see. Honestly I hope they fix it. But given how they play dumb and make you feel like you have no idea what you are talking about..I will never have them work on anything else.
coffeeguy57 is offline   Reply With Quote
