Old 05-10-2015, 10:27 PM   #31
Left Coast
Originally Posted by mike.t View Post
Sorry bob i thought you were asking. OK OP just for me to learn something. What is this 456 in? Don't think it is a tow vehicle nor an RV.
My understanding is he's had it since new (2000/2001) Dodge Durango and I guess he just wanted to wake it up some. Hope he doesn't need to make a coast to coast trip....be spendy!
Old 05-10-2015, 10:36 PM   #32
mike.t's Avatar
Thanks bob. That 456 will wake it up and correct your are don't go far;o)
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-10-2015, 11:47 PM   #33
its been many years since I adj my gears in my 57 chevy, I did it by feel and grease and had no noise, it sounds like the set up was wrong . and why did you change from stock?
Big Bill is offline   Reply With Quote
Old 05-11-2015, 10:17 AM   #34
No drag racing for me. I'm using this as a TV fr my Forest River TT . The 4.56 livens it up a bit for towing. Cheaper than buying a new rig, I just broke it in at 103K miles.
coffeeguy57 is offline   Reply With Quote
Old 05-11-2015, 01:37 PM   #35
They definitely do not have the pinion depth set properly. This has to be done first so the pinion teeth are contacting the ring gear teeth at the proper angle and pitch. This will cause the noise if not perfect. This job requires a knowledgeable Technician to get it right. Driving it will only cause a bad wear pattern to form on the gears. They may never be quiet if driven to much. In my 40 plus years as a Master Tech I only knew a few guys that set these up correctly.
I wish you luck.
speedozeke is offline   Reply With Quote
Old 05-11-2015, 02:48 PM   #36
mike.t's Avatar
Any local speed shop should be able to set the rear end up. Where about's are you located? It will liven it up a bit however your mileage will suck big time and expect not to go very fast.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-11-2015, 03:06 PM   #37
I'm in Eugen Oregon. It does well pulling the TT keeps it right in the power band @ 55- 65. It holds od fine th straight flat at 60 so I'm good. Mileage sucks anyway while towing a wall back there.
Old 05-11-2015, 05:58 PM   #38
toslow's Avatar
i got a buddy in that neck of the woods, don't know if you know him or not.
his name is mark mcnutt
haven a blast
toslow is offline   Reply With Quote
Old 05-30-2015, 09:19 AM   #39
Just got my rig back, shop replaced the rear ring and pinion. It is much quieter but still has noise at highway cruising speed. It of course goes away if i pull it out of gear, accelerate or let off the throttle.
Shop explained it away as "normal'"with a higher ratio gear set. Of course they did this the last set as well. Shop Manager did say the pattern didn't set right on the first set.
I have a feeling its just going to get louder as it did before. At this point it has about 100 miles that the shop put on the gear set. I may take it somewhere else to take a look.
Old 05-30-2015, 09:39 AM   #40
TURBS's Avatar
He's obviously a scam artist.
This is funny to no end.
I've got 534 gears in a car I have and you cannot hear any gear noise what so ever!
Btw, I didn't notice but did they replace all the bearings in the rear end ? Those early 2000's Durango's had bad bearing issues.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
