Originally Posted by MikeT5200
I probably should have explained it better. It's the 'sway bars' pivoting in the head that is different from side to side. When I take the bars off of the "L" brackets/plates one side is really hard and the other side not as hard. Both sides are torqued to 65#.
And it looks like I can put the bars on either side.
I understand. See my previous post about being level. I know there are times when I attempted to disconnect that one side basically falls off (after jacking) while the other takes some additional lifting or strong arm strength.
If the problem follows a particular arm then you may have a problem with the head or one of the bars.
You may not even realize you're not level.
