Old 06-08-2013, 06:54 PM   #91
transamz9's Avatar
Originally Posted by jevanb View Post
I have a nicktane adapter in place of my factory filter and I run 2 micron CAT filter vs the 10 micron factory. I also have a airdog lift pump with watersep filter and 2 micron fuel filter (cat filter) in it`s place. my total fuel filter cost (3) every 10k miles is around 30 dollars, vs 40 for a single factory. plus the added benefits of cleaner fuel to my CP3 and positive pressure instead of vacume pulling fuel. cant understand why GM did not take the recommendation of BOSCH like dodge did to install a lift pump
Yeah, I could never understand the no lift pump thing either. How much more would it have added to the price of the truck? Couldn't be much. For the most part they hold up though. That is something I need to do to mine , add a fuel pressure gauge. The Cummins is known for the the CP3 pump going because the lift pump quits and causes extra stress on the CP3. I run a pretty hot tune 100% of the time so it worries me sometimes. So far so good but my truck is starting to get some age on it ('05) and it's been running the tune for a few years now pulling my train.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 06-08-2013, 07:45 PM   #92
jevanb's Avatar
Talking
when I run my maxeffort tune (around 250HP) I can drain the rails pretty quick and pop a code, with the lift pump set at 12psi it never happens, the 40over injectors really like to pass fuel but it is starving for air, but not for ever the twins are on the way s475 over factory
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 06-08-2013, 08:00 PM   #93
funnthestix's Avatar
I spent a 5 1/2 yrs towing with a gm 6.0 gasser it did the job but left something to be desired. 3 weeks ago I found a 01 f250 with the 7.3 power stroke with only 26xxx. the first time towing with it sold me on diesel.
2008 wildwood 29fkss
2001 Ford F250 w/7.3 Power Stroke diesel
funnthestix is offline   Reply With Quote
Old 06-08-2013, 08:06 PM   #94
transamz9's Avatar
Not putting your truck down because you have a great truck and motor but you should go test drive a new(er) one. You think power......This is what you would look like.
2006 EZ GO 6" lift
Old 06-08-2013, 08:17 PM   #95
jevanb's Avatar
a friend of mine put over 500k and never did anything to it towing all the time. my father in law is retired GM and bought a 2000 7.3 he has 240k and tows 18k 3 times a week and it is going strong. You got a great motor that will last forever. just keep cam position sensors in the glove box because they go out all the time, or every 10-20k, at least the inlaws and 2 friends motors do
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 06-08-2013, 08:28 PM   #96
onetonford's Avatar
On mine I only changed it when they had a recall for it and so far it has gone over 85000 miles with no problem with the cps only major problem I had was when I bought bad deisel and it plugged the fuel filter. I now only buy diesel from a station that has high volume sales such as a truck stop.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
