Old 06-07-2013, 09:12 PM   #81
jevanb's Avatar
Originally Posted by jlbreaux View Post
.I will take torque over horsepower any day! Better for pulling, racing and or mudding.
HP is what keeps you accelerating not TQ, I see 550HP @3300 RPM and a gas engine would have to run way more RPM,thats is what makes diesels a better platform , on the flats a 360HP diesel and a 360HP gas is equal, but add throttle to accell, or a hill and the higher HP in lower RPM will out perform. but it sure is nice the have the extra TQ when I need to get rolling
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 06-07-2013, 09:38 PM   #82
boatman
boatman's Avatar
The differance is trans locked in 3rd gear engine screaming at 3 grand and getting 8 miles to gallon VS cruise control on at 65mph trans in OD purring along at 1900RPM and never downshifting or taking out of cruise getting 12mpg. Love the Dmax
boatman is offline   Reply With Quote
Old 06-07-2013, 09:39 PM   #83
transamz9's Avatar
Originally Posted by jevanb View Post
your post said the chevy diesel cost more to maintain. I do the same maintaining as your cummins and it does not cost me more with my chevy diesel
I apologize, I was thinking the D-max held more oil than it does. You fuel filter is $10 higher than mine but holds two less quarts of oil. So yes the D-max is as cheap as the Cummins.
I pay:
$9.95 for a fuel filter
$4.63 for an oil filter
$12.97 each for three gallons of oil
I clean my air filter.
That's $53.49 every 10,000 miles.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 06-07-2013, 09:50 PM   #84
transamz9's Avatar
You have this all wrong. Torque is what keeps you accelerating. It takes torque to over come the force. Horsepower is just a mere number that is used to tell you how much work can be done over a distance in a time frame. You can't have hp without torque and rpm's but you can have torque without hp or rpm. Also, torque can be multiplied by gearing, horsepower can not.
2006 EZ GO 6" lift
Old 06-08-2013, 06:52 AM   #85
jevanb's Avatar
why are all ET calculators in hp. and they have no bearing on TQ. the only required info is weight and HP it could be a 3300lb 200hp car or 400hp 7100lb truck. when I got off the dyno with my #`s and weeks later hit the strip the calculator was almost right on (minus reaction time)
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 06-08-2013, 07:37 AM   #86
transamz9's Avatar
Because that's what hp is. It's a number that you get when figuring work done over an amount of time. The torque is what did the work. A dyno measures how much torque you are applying to the roller at a given RPM. That gives you the hp at that RPM.
torque X RPM / 5252 = hp
2006 EZ GO 6" lift
Old 06-08-2013, 08:03 AM   #87
Originally Posted by B47 View Post
I think we all need to stop throwing these claims around until and unless they can be backed up with solid data.
At this point, it's all about personal opinions and nothing else.
Just saying -
X - 2
grayfox is online now   Reply With Quote
Old 06-08-2013, 03:59 PM   #88
Coops1's Avatar
I pay:
The filter may cost more but we don't need to change it every 10, I have 16K on mine and wont need to change it for another 15K or more.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 06-08-2013, 04:26 PM   #89
jevanb's Avatar
I have a nicktane adapter in place of my factory filter and I run 2 micron CAT filter vs the 10 micron factory. I also have a airdog lift pump with watersep filter and 2 micron fuel filter (cat filter) in it`s place. my total fuel filter cost (3) every 10k miles is around 30 dollars, vs 40 for a single factory. plus the added benefits of cleaner fuel to my CP3 and positive pressure instead of vacume pulling fuel. cant understand why GM did not take the recommendation of BOSCH like dodge did to install a lift pump
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 06-08-2013, 06:43 PM   #90
transamz9's Avatar
To each his own I guess and I could go much longer too but $10 for my filter, I will just change it at every oil change. Cheap insurance and a 30 second job.
2006 EZ GO 6" lift
