Old 08-20-2016, 03:49 PM   #11
raspivey's Avatar
The oil calculations in the newer cars seems to be much better than the older systems. I've been told they calculate based on RPM, engine temp, exterior temp, and a number of other factors. My SS Camaro went around 10K miles on 8.5 qts. of synthetic and never had any issues after 81,000 miles. My Corvette gets about the same on 10.5 qts of synthetic. I just had the motor apart for a cam / heads / bottom end job at 75,000 miles and there wasn't any sign of abnormal wear (and I drive it hard). So, I'd just let the light come on and change it then.
I don't know exactly how true it is, but I've also heard that the newer trucks with a tow mode will change the calculations when towing to account for the increased load.
2012 Chevy Tahoe LTZ - HD tow package
Old 08-20-2016, 03:54 PM   #12
Georgia Frog Rally 2017
aceinspp's Avatar
There are times when one can not change the oil when the time arrives as being told by a computer. Best advice change at your earliest convenience. Your not going to hurt anything as long as your using good quality grade oils. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-20-2016, 06:35 PM   #13
Just do a reset now, stick to your 3-5K schedule and then remember to reset it each time you change your oil and it will never go on again.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-21-2016, 08:47 AM   #14
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Personally, I would stick to your schedule and not worry about it. Just reset it and change the oil on your own calcs.
325BH is offline   Reply With Quote
Old 08-21-2016, 09:20 AM   #15
On my 2012 Ram 6.7 diesel it comes on at 7500 mile intervals period. Doesn't matter what happens in between.
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 08-21-2016, 09:57 AM   #16
Thanks, everyone. I'm just going to reset it and change it after 3000 miles. I just can't imagine that it really needs it at this point.
gspot01 is offline   Reply With Quote
Old 08-21-2016, 11:52 AM   #17
m2kamp's Avatar
Did you have a lot of time idling? Excessive idling will dump tiny bits of fuel into the oil. The oil monitor computer will account for this.
In the owners manual it states that if extended idling time, then switch to severe service schedule.
Hope that helps
2015 Wildwood 26TBSS / Fastway e2 1k WDH
2016 Ram 2500 CC 6.4L 4x4
m2kamp is offline   Reply With Quote
Old 08-21-2016, 12:25 PM   #18
I agree, do that. I expect it was not on in July and you failed to reset it.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
