Old 12-31-2012, 12:23 PM   #11
buzzmonster's Avatar
I would have to say I agree - you are going to be bust on payload. We have a payload capacity of 1864 in our ecoboost, and an actual tongue weight of 630lb. Believe it or not that payload goes mighty quick. Full tank of gas 223lb, driver 200lb, wife and kids, hitch, 2 mountain bikes, 2 kids bikes, stroller, kids toys, chairs, and a mass of fire wood we have about 500lb of extra payload. Now we can seat 6 in the truck so when the grand parents come we get closer and closer. No issue towing the trailer as we can tow 11,300 lb but payload .... another matter.
having been there and done that with an undersized TV (we originally tried a v6 pathfinder) you will be amazed at how much the weights add up, and you don't want to be second guessing the weights the whole time.
2011 F150 Ecoboost Screw 4x4 c/w max tow
2010 Roo 21RS
buzzmonster is offline   Reply With Quote
Old 01-06-2013, 12:05 PM   #12
Originally Posted by dwaynerz View Post
im sure there are some out there, but when was the last time any of us saw a 150 lb driver, or even 150 lbs for that matter ourselves
47 yrs old and I'm at a heavy weight for me at 150lbs 5'7"
Have a friend with a 2012 F150 Max Tow/Max Payload Ecoboost who recently purchased a 5'er & I've warned him that he has too much trailer for his truck
Night_Wolf is offline   Reply With Quote
Old 01-06-2013, 12:08 PM   #13
Bodean614's Avatar
We had 07 f150 with tow package and got the 5.7 2012 hemi 1500 and the dodge out preform the ford in every aspect. Not find of fords since they have issues with cam sensor and won't fix them.
Bodean614 is offline   Reply With Quote
Old 01-06-2013, 12:15 PM   #14
CampingQueen
Keep the TT and get a bigger truck!
2012 Flagstaff V-lite 30 WTBS
2011 Ford Expedition
4 kids and a hubby & never enough time to camp!
2011: 17 nights 2012: 26 nights 2013: 46 2014: 20 2015: 16
arlee453 is offline   Reply With Quote
Old 01-06-2013, 01:55 PM   #15
Dave_Monica's Avatar
I know we're straying from the original post, but your friend with the F150 with max payload has as much payload capacity (by GVWR) as 3/4 ton diesel trucks. They have a GVWR of 8200 lbs and depending on equipment, weigh around 6200 lbs loaded ready to camp.
Dave
Old 01-06-2013, 03:44 PM   #16
Dave
While that may be true the RAWR of only 4800 lbs. still needs to be watched closely.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 01-06-2013, 04:09 PM   #17
Herk7769's Avatar
Ford is one of the manufacturers that offers several different "tow packages" and suspension packages.
You may think you can use the MAX TOW numbers and/or the higher GVWR numbers but few dealers order lot trucks with both (or even any).
Unless your window sticker said MAX TOW and HD Suspension package you may be shocked to find out you are no where near the advertised numbers.
HAM CALLSIGN - KC3FFW
Old 01-06-2013, 04:22 PM   #18
Dave
True but the 3/4 diesel is only a rear spring away from a 1 ton. The F150 is maxed out in the HD model, but theres still an upside to the 3/4 ton.
goduc is offline   Reply With Quote
Old 01-07-2013, 12:06 AM   #19
Dave
His truck has the Max Tow and AFAIK Max payload. That being said his 5'er will put almost 1500lbs in the box on the king pin and will weigh really close to 10K when loaded. Not a combination I'd want to run and I own an Ecoboost, so I am very familiar with how it hauls. I'll be shocked if it doesn't get pulled over in BC due to their normally strict enforcement on towing TT's and 5'ers
I should note that Ford doesn't even offer the option of a Kingpin or Goose neck in the F150 series; you need at least a 3/4 or 1 ton and then you need to have the 8' box to get that option (at least from Ford) I've seen many 5'ers being towed with 6.5' boxes
Old 01-07-2013, 12:09 AM   #20
Your 07 and the current Ecoboost 3.5 are worlds apart Now that 5.7 Hemi is a sweet motor; I have driven one and was very impressed, but I haven't towed with one
