Old 12-30-2012, 07:22 PM   #1
Ok another tow question,think I'm ok but any opinions
I have a 2012 ram 1500 big horn, crew cab, auto,4x4,tow package,factory brake controller,3:55 rear,tow capacity 8500 lbs,1455 lbs payload, on the door sticker says 6800 lbs gvwr,3900 lbs each axle, I am ordering a wildwood 30kqbss and the sticker says dry weight 6884 and hitch weight 899 lbs.I added a few extra factory options and figure I'm just under 7000 lbs on the dry weight.My question is I want an equalizer hitch with sway controller, do I get a 1200 lb hitch and does anybody tow this trailer with this truck.I think I will be ok with this set up,anybody see any problems here,i am guessing i need to keep payload,people,accessories,water,etc under 1500 lbs.thanks
Amcmachine70 is offline   Reply With Quote
Old 12-30-2012, 08:26 PM   #2
MtnGuy's Avatar
That is a big trailer.
The dry weight of that trailer is going to be around 7300 lbs. with options, propane, and a battery. Still under the 8600 lb. tow rating of the truck, but after loading with camping gear, I betcha you will be close. The website does not list the GVWR, but if you add the dry weight and the cargo carrying capacity, that adds up to 11,000 lbs. You are gonna have to load the camper really lite.
The listed 899 lb. tongue weight will grow significantly, but 1200 lb. spring bars should work.
Many times, the receiver hitches are rated just at or a little above the tow rating. This probably mean that your hitch is rated for something like an 860 lb. maximum tongue weight when using a WDH. The tongue weight of that camper is probably going to be in the 1100-1200 neighborhood. There should be a sticker on the hitch stating the weigh capacities.....make sure the hitch is up to the task.
Another problem is going to be the truck payload. Even if you had a "true" 1455 lbs of payload, the tongue weight is going to seriously dip into that number. Even if the trailer has only a 1000 lb. tongue weight, that is going to bring your left over payload in at 455 lbs. Figure your weight, your spouses weight, and your kids weights (presumed since that trailer is a bunk house model), and bed cargo might be, and see if that number comes in under 455 lbs. The best thing to do before signing the order form, is to load up the family, load up the bed with expected camping gear, fill the tank, and head to the local quarry or landfill and see if they will weigh your truck. Take that weight, subtract it from the 6800 lb. GVWR, and then see if you can add another 1100 lb. tongue weight and still stay under the 6800 lb GVWR.
IMHO, that trailer would be better pulled by a long wheelbased, 3/4 ton truck or bigger.
Old 12-30-2012, 08:34 PM   #3
Dave_Monica's Avatar
The payload of 1455 lbs is with a 150 lb driver and nothing else. It's always best to head to the scales with full fuel, people and gear that you'd be carrying and get the front and rear axle weight. The payload available for tongue weight will be the truck's GVWR (6800) less the actual scaled weight. It's interesting to look at the scaled rear axle weight and compare it to the truck's RAWR (3900). You will have more payload available by this method.
Don't be surprised that the actual payload by GVWR is only around 1000 lbs (my '05 Ram was 950 lbs and it was RWD). The payload by RAWR should be 300 - 400 lbs more.
The camper you're buying will probably be closer to 7200 lbs by the time you add a battery and propane and any dealer installed options. Typically you carry about 1000 lbs of stuff in the camper which would put the loaded camper weight around 8200 lbs. The recommended tongue weight of 13% would be 1066 lbs.
I think that you'll be over the truck's GVWR but below the RAWR, plus near the max tow limit. You'll be at or near the max limits of the truck...may not make a comfortable towing situation.
Dave
Old 12-30-2012, 08:54 PM   #4
phat phrog stunt crew
im sure there are some out there, but when was the last time any of us saw a 150 lb driver, or even 150 lbs for that matter ourselves
dwaynerz is offline   Reply With Quote
Old 12-30-2012, 09:13 PM   #5
acadianbob's Avatar
And your hitch may not be rate for 1,000 pounds? Better check.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 12-30-2012, 09:25 PM   #6
Ok good advice coming in thanks, checked my factory hitch rating it is 12,000 lb towing and 1200 lb tongue weight with weight dist. Hitch.so far it seems I may be at max capacity here,tough situation here, truck is mine for 3 more years and wife really likes the outdoor kitchen setup on this model.what to do. What to do.
Old 12-30-2012, 09:50 PM   #7
Of course it depends on what you intend to do with your camper.
If it is mostly for "nearby" camping trips, where you can take your time and be safe, while maxed out, you should still be ok. I assume you have a hemi.
But if you intend to go on long trips at freeway speeds, and possibly forced to travel in high winds or other tough conditions, that is a different matter.
bakken is offline   Reply With Quote
Old 12-30-2012, 10:04 PM   #8
asquared's Avatar
As others have stated you may have too much tt for the truck which can make for a white knuckle ride. Yes 1200 lb bars should be adequate but you may want to step up to something like a hensley arrow hitch to help you out. Your trailer is likely to weigh over 8000 lbs loaded and could weigh upwards of 9000 lbs depending on how you load it. Most people add between 1000 and 1500 lbs of stuff to a trailer. All those plates, pots, pans, clothes, chairs etc add up quickly. If it helps you at all, my tt weighed 5700 lbs when we left the dealership and now weighs 7000 lbs loaded ready to camp, this is for a family of 3. Remember your loaded tongue weight should be 13-15% of the loaded tt weight.
As others have said go weigh your truck with a full tank of fuel, all passengers, pets and gear. Take the weight you obtain and subtract it from your gcwr to get your adjusted towing capacity. Take the scaled weight and subtract it from the tv gvwr to get your available payload. Your tongue weight needs to be subtracted from your available payload. If this results in a positive # then you are probably ok. If it results in a neg number then you are in for a rough ride and probably a tv upgrade in the near future.
asquared is offline   Reply With Quote
Old 12-31-2012, 02:00 AM   #9
I have a 2012 1500 5.7 2 wh 3:55 rear . First you will need air bags in the coil springs . You will for sure need a good WD hitch ! The coil spring air bags is an easy DIY IF, IF you are handy . If you are towing local , you will be all right if you have the WDH & the air bags . Air lift 1000 are the best best bags . Here (below) is a link to what I used . Cheap $86 . Took me 2 hrs to install . Be careful . I hope this isn't your first towing experience ? Jim
2009-2012 Dodge Ram 1500 1/2 Ton Pickup 2WD & 4WD - Air Lift 1000 Air Helper Springs [REAR] - 60818 | $88.62
FarmerJim is offline   Reply With Quote
Old 12-31-2012, 10:59 AM   #10
Cancell the order and find something smaller/lighter. You'll be stuck with that combo fo years and hate it.
goduc is offline   Reply With Quote
