Old 10-20-2014, 05:54 PM   #21
davel1971's Avatar
I paid under 48000 for a 2014 3500 cclb. Rides better than some half tons I've had
David & Lynn
Old 10-20-2014, 05:57 PM   #22
LaydBack's Avatar
I noticed you said this is new adventure. I bought 2 trucks and 2 trailers in 2 years.....I run the B&W turnover ball setup in a 2012 F350 DRW diesel. Not towing, the truck was averaging close to 16mpg with mixed driving (city/hwy), towing is around 10mpg with a 42', 15k lb. trailer. My buddy has a F250 and was getting around 19mpg, mostly highway. Safety and stability were what mattered most to me, and the DRW is what I opted for, and it took all the questions out. When you mention toyhauler, I definitely think 1 ton for sure, and I'm sure if you cruise the interstate, you'll see lots of people doing it differently. The ultimate decision is what will get YOU there safely, and without causing harm to others.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 10-20-2014, 06:06 PM   #23
asquared's Avatar
Due to dealer screw up, I paid a little south of $43k.
I get about 16 mpgs with my chevy. I don't feel as though my ride is all that rougher than my old cushy armada. The only time I notice it is when I get chucking from the fiver. Working on a solution to that problem now. The b&w turnover is probably the best solution out there for using the bed.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-20-2014, 06:49 PM   #24
Sgt. Schultz's Avatar
Originally Posted by SKYDRIFTER350 View Post
well I just looked at the Chevy web-site....
Joel...are you referring to the weight that goes in the bed from the 5th er tongue weight?
I see the 2500 can take almost 2800lbs and the 3500 can handle lots more like 4300lbs.....well this is max payload numbers ... I guess whatever you got except the basic truck??? I have seen several 5ther's with 'pin' 'tongue' or whatever you call it weight in the 2500-2800 lb range...so I guess this does take it out of the 3/4 ton capability huh..?
Am I right with all this?
Damn....this thing keeps growing & growing!!!
OP I think you are doing this the right way - get your info before spending your cash
A small 5th TH like
Stealth Toy Hauler Fifth Wheel by Forest River
can have a pin weight over 3500 lbs when using the 25% numbers
A big 5th TH like
Catalyst Toy Hauler Fifth Wheel by Forest River
can have a pin weight over 6000 lbs using the 25% rule
Know your numbers - Learn To RV: Towing Pin/Tongue Weight Calculator
For a 5th hitch --
B & W Trailer Hitches | Trailer, Tow & Truck Hitches
Reese - 20K / 22K / 25K Fifth Wheel
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 10-20-2014, 06:50 PM   #25
Taranwanderer's Avatar
No one has asked the original poster what his needs are. As in, what does he intend to put in the TH? How many people are going to be with him? If it's just him and a motorcycle, he doesn't need a 43' long TH with a 2900# pin weight, and a 2500, short bed, SRW with a B&W system and 30' 5th wheel TH will work just fine for him. Stop trying to sell him more set-up than he may need!
So, to the OP: what is going in the toy hauler, how many people will be traveling with you normally, and how long of a rig do you anticipate wanting or needing? Let's answer these questions, and go from there.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-20-2014, 07:03 PM   #26
Thanks Everyone!! lots of info....
in an earlier post I kinda laid out what I'm looking for....
Primarily just me with occasional guests..
I have a sport 4-wheeler & a sport-touring bike....about 1000lbs between the two.
1000lbs tools/BS
couple of bicycles/surfboards/snowboards
want a front bedroom set up
100 gal H2O...Generator
not really concerned about slide-outs...
I was figuring I would only be able to afford something on the smaller scale of 5th wheels???
SKYDRIFTER350 is offline   Reply With Quote
Old 10-20-2014, 07:09 PM   #27
SGT Shultz...I like that first one you linked...the Stealth... can you tell me what something like that costs new? If you know..or anyone?
good info on the hitch too. thx..
Old 10-20-2014, 07:26 PM   #28
Skydrifter - sorry I am north of the 49th - the prices up here will be a whole lot more than your neck of the woods
looking here Giant RV I would guess in the 35 to 40k before negotiations - or less depending on the State you find the one you like in
PT Avenger 33BHS-TE
Old 10-20-2014, 07:29 PM   #29
wbdavey's Avatar
Skydrifter - I think you've got the cart (truck) before the horse (5th wheel). I suggest you decide what 5th wheel toy hauler you want, then find a truck that is MORE than capable of towing it. My experience - I bought a 2005 Titanium toy hauler that was 40 feet long and fairly light at 13,500 pounds. Had it delivered to a campground and paid the delivery driver to have it weighed on truck scales. I knew exactly what the pin and total weights were BEFORE I went truck shopping. I bought an 05 F350 SRW short box and Pullrite Superglide hitch. I found that the F350 was only a few hundred dollars more than the F250 but had a much higher cargo capacity (ability to carry the pin weight of the trailer). The ride when not towing was very smooth and I used the truck for a daily driver for 7 years. Why can't you take a test ride in a few 1 tons and 2500's and decide for yourself.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-20-2014, 07:39 PM   #30
davel1971's Avatar
3/4 tons are not worth buying in my opinion if you are going to be towing anything. Virtually no price difference to get a single wheel 1 ton.
And before someone says it, NO airbags aren't the solution
David & Lynn
