Old 10-21-2014, 02:53 PM   #41
MtnGuy's Avatar
With the OPs OK, I moved this thread to the Towing Forum. This thread pertains to all 5th wheels, not just Toy Haulers.
Old 10-21-2014, 03:10 PM   #42
I have a 2011 GMC, 1 ton drw, 4x4, crew cab, long bed. I pull a 35 ft 5er. In the bed is a 50 gal. fuel tank behind the cab. When dry camping, which is most of the time, I put in a 50 gal potable water tank behind the fuel tank and in front of the 5th wheel. I had a 2001 GMC 3/4 ton prior to this truck. It was overweight when everything was loaded. My present truck is the daily driver. I'm retired so no going back & forth to work. I don't regret the bigger truck at all. It tows like a champ and the mileage isn't too bad. Anywhere from 9.5 to 13 mpg towing, depending on wind and terrain. It's a truck and doesn't ride like a caddy. Get the bigger one and then no regrets afterwards. My 4 cents worth.
Pipeman is offline   Reply With Quote
Old 10-22-2014, 07:24 AM   #43
Originally Posted by MtnGuy View Post
A 1 ton truck is about $1000 more than a 3/4 ton truck with the same options. If I am going to spend over $50,000 on a new truck, that is only a 2% price shift.....a small price to pay for the added payload and safety.
Actual price difference is only about $400.00, or at least that was the case in the truck I bought. As other have mentioned, going the 1 ton route is the way to go. The unloaded ride is the same as a 3/4 ton (loaded ride is noticeable better), the price difference is small, and the increase in Payload (trucks rated carry capacity) is about 1500lbs.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 10-22-2014, 04:17 PM   #44
davel1971's Avatar
You are very right. Makes zero sense to buy a 3/4 ton when you can have a single wheel 1 ton for virtually same money and have a 50% increase in payload capacity
David & Lynn
Old 10-22-2014, 06:47 PM   #45
well...not too long ago I figured out the truck is going to be expensive,,,,very expensive...
I am not gonna worry about a few bucks here or there!
3500
SRW
LT trim
Z-71
Bucket seats
Diesel
4x4
Long Bed
& all the little nick nacks that look good to me when I order it
Comes out to $60,230 or something like that..on the Chevy website
SKYDRIFTER350 is offline   Reply With Quote
Old 10-22-2014, 06:58 PM   #46
davel1971's Avatar
I have a 2014 3500 just like you listed. Well equipped, but not loaded. Sticker on mine was 54,000. I paid about 47ish. Seen many half tons cost way more than that.
David & Lynn
Old 10-22-2014, 09:28 PM   #47
Looking at GMC too....anyone have an opinion on those?
Old 10-22-2014, 09:44 PM   #48
asquared's Avatar
Make sure you get HD towing package options. If given an option always go with the 11k gvwr over 10k gvwr. Get your dealer to look for a 2014 leftover or even look for a newer lightly used truck to save some $.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-23-2014, 08:37 AM   #49
But a similarly equipped half ton can be purchased for about 15K less than that!
Old 10-23-2014, 08:47 AM   #50
transamz9's Avatar
3/4 tons are not worth buying in my opinion if you are going to be towing anything. Virtually no price difference to get a single wheel 1 ton.
And before someone says it, NO airbags aren't the solution
I know the OP is buying a truck and yes he just as well by a 3500 but your statement about airbags is not true for someone that already owns a 250/2500.
Still till this day my 2500 handles my 5er better than my '13 3500 SRW with just short of 4000# of payload and the air on board is a very useful tool. You just have to buy the right system.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
