Old 09-21-2012, 07:40 AM   #11
MtnGuy's Avatar
Wow, a lot went on with this thread while I composing my last post.
Looking at the photo of the truck and trailer, you probably need to tilt the head assembly back at least 1 more notch if you want to use the same chain setup. And that would be after you get another hitch shank with more drop. You are gonna have to get your head assembly lower.
Check out the options here: etrailer.com - Products reese shank
Old 09-21-2012, 07:42 AM   #12
MtnGuy's Avatar
Originally Posted by MilCop4523 View Post
the pic of the receiver and ball was taken last night after I flipped the bar. I figured that the ball would need to be dropped and the only way to do that was to flip the bar and reinstall the ball at a lower point.
That way, once the weight of the trailer is applied the truck rear end drops.
Weight displacement chains are applied at the point where the tougue weight is on the ball but not totally supported by the truck reciever alone - correct?
Then I can drop all the weight of the trailer onto the truck and adjust the air system to level the front of the TV to the rear - Correct?
I was lead to believe that the picture of the hitch was the setup used with the truck and trailer picture. Now I understand that that is not the case ??
If the setup of the pictured hitch was used for the picture of the truck and trailer, then a new shank with more drop will be needed, plus the head assembly tilted back more. If the picture setup is a new setup, then you need to try it out to see if the trailer rides level, and truck ride level....with minimum pressure in the air shocks.
Old 09-21-2012, 07:49 AM   #13
MilCop4523's Avatar
My truck and trailer in the lot pic was taken without air bags with the shank pointing upwards.
Since I figured I needed to lower the ball substantially lower I have to reverse the direction last night on the shank.
Saturday I have to haul it out onto the Subdivision road and find a flat piece of pavement and play with the adjustments.
I can't go lower with the shank and the ball attachments.
the one I'm using is
Trunnion-bar system:
  • Distance from center of ball hole to hitch pin hole: 14"
  • Rise: 6-1/2" from top of hitch receiver tube opening
  • Drop: 1-1/4" from top of hitch receiver tube opening
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 09-21-2012, 07:51 AM   #14
Road-King's Avatar
This was it before the air system installed.
The front end was actually higher than the back.
I think you will need a new shank with a longer drop. I don't have air shocks, but when I got my new TT, I used my old WDH from my old 1/2 ton pick-up. My current truck is a 4X4 dully. The drop on the shank I had was about 3" too short.
If you install a new shank, you have to go through the whole process of setting up you WDH, again....
etrailer.com - Products shank
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-21-2012, 07:51 AM   #15
MilCop4523's Avatar
I may need to go with the Reese Accessories and Parts - RP63971 shank
and
Old 09-21-2012, 07:59 AM   #16
MtnGuy's Avatar
Flipping the hitch shank should give you enough drop so that the trailer now will ride level. If you kept the same head assembly tilt, that may actually increase the spring bar pressure, which by the look of your truck attitude, that will be a good thing. Regardless, a trip to the scales is always good.
Old 09-21-2012, 08:02 AM   #17
Why the airbags? A pickup is designed to run lower in the rear with a load in the bed.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-21-2012, 08:22 AM   #18
MilCop4523's Avatar
Air bags were to take the "we're on a ship" pitch and roll out of hauling.
Without them it was an aircraft taking off in the front end. Trailer is well below the tow weight of the vehicle.
Just with the set up being advanced with the air its lifted the center.
Looking for the correct sequence to follow based on others experience in adjusting the height of the shank then the ball then the air bags.
With 10 lbs in the air system, the shank dropped and the ball on the lowest settings I am at 25 inches ball height (if memory serves correct from last nigh.)
The trailer sitting level is 22 to where the ball connects and locks.
A 3 inch difference at the back bumper. Add the TT weight to the tongue and that will drop. Add the WD chains and the rear end will rise again pointing the trailer hopefully level Correct???
that should also take the front of the truck from an upward position which is what we had before in the picture submitted to a more level stance.
Air used to final adjust ride for bounce effect on our great level roads.
So if I took all my air out of the bags (they were bump stops prior) that should set the truck back to factory measurements on level pavement.
TT receiver is 22 inches at level supported on tongue jack. Should that remain similar once loaded onto the truck with WD chains added?
and
Old 09-21-2012, 08:33 AM   #19
MtnGuy's Avatar
The ball should be about 1" on the unhitched truck above the trailer tongue height. If you are now at 25" with the lowest bolt holes used, you may have to get 1 of the extended drop shanks. Don't go too overboard....you don't want that puppy dragging the ground. Before buying another hitch shank, see how the current setup does.
I think a properly setup WDH would have gotten your truck level without the air shocks/bars. IMHO, the hitch head was not tilted back enough for the chain lengths used in your photos.
The 1st post indicated air shocks, and now the referral is to air bags ?? Which is it ?? Air shocks may require some pressure, but I think air bags can be run at no pressure ?? That is the way to set up your truck if you can.
What weight spring bars are you using ?? With a listed dry tongue weight of 720 lbs., you should probably be using 1200 lb bars.
Old 09-21-2012, 08:44 AM   #20
Road-King's Avatar
Found this on-line when I was setting my WDH up. Maybe it will help;
"Park the TT and truck on level ground... Level the TT (using the tongue jack) by measuring the frame front and back with reference to ground level... Measure from ground level to inside top of trailer ball coupler... Record this measurement...
Set unloaded ball height on truck hitch head about 1/2' to 1" higher than this measurement... The exact amount will depend on the stiffness of your truck suspension...
Measure all four truck wheel wells with trailer unhooked... Record this measurement...
Hook up trailer and snap up w/d bars so TT appears to be level... Measure truck wheel well distance again... If front of truck is same height as, or slightly higher than, the unhitched height, you're done (not likely on the first try!!)...
If front of truck is not at or close to the unhitched height, adjust w/d bars as necessary...
If the front is too high, you may have to increase w/d head tilt and/or decrease tensioned chain link count to achieve more w/d bar tension...
If the front is too low, you may have to decrease w/d head tilt and/or increase tensioned chain link count to achieve less w/d bar tension...
The amount of tension required will depend on TT tongue weight and on TV and TT dimensions...
Round style W/D bars should be parallel with trailer frame when these adjustments are complete... If W/D bars are not level with TT frame using a given number of chain links (5 minimum) or the trunnion bars are not slanted downward slightly, tilt w/d bars up or down with adjustment screw, washers, etc., (whatever method is employed on your hitch) and readjust as required, dropping or picking up chain links as needed for necessary tension while maintaining a level condition to the TT frame...
Check the truck's front end height again after these adjustments...
Most hitch manufacturers want to see at least 5 chain links between the snap up plates and w/d bars (under tension)... This is to avoid binding of the w/d bars in turns and when backing...
Once you have achieved the proper truck front end height, check TT for levelness again... If TT is not level, adjust ball height on hitch head as necessary to level TT... If you can't achieve perfectly level, opt for a bit nose down... This will increase TT rear end clearance on sloping driveways and add a bit more hitch weight as the TT center of gravity shifts forward a bit with the nose down...
All these adjustments will interact with one another to some degree so a few readjustments will most likely be required...
When you are done, the w/d bars should be level (except trunnion w/d bars), the TT should be level and the front of the truck should be close to or slightly above the unhitched height...
It's pretty tough to get everything EXACTLY perfect, but get the TT as close to level as you can and the front of the truck as close to the unhitched height as you can... My truck is almost equal squat, maybe a 1/4" lower in the back... Avoid the front end of the truck being lower than the unhitched height... This indicates too much weight is being transferred to the front axle and could cause handling problems and excessive front tire wear...
My TT is level within 1/4" front to rear, being a bit nose down... My w/d bars have an upward set to them, but the Pullrite hitch adjustment is a bit different than others as it's w/d bars do not flex like a normal w/d hitch... So that part is pretty normal for my Pullrite hitch...
The procedure sounds difficult but really is not... It can be a bit tedious trying to achieve a perfect condition, but is not difficult... You should be pretty near perfect after a few readjustments and you'll probably find your TT tows and handles much better...
I have seldom seen a hitch adjustment from a dealership that couldn't be improved on with a bit of fine adjustment...
Best Regards,
Les"
Russ & Kim
2014 Alpine 3600RS
