Old 06-08-2016, 03:53 PM   #21
Commercial Member
Be careful with CAT scale. Their "official" policy is on one side weights. Some locations even have guard rail close to side so you can't get off the platform.
In that case you have to assume you are about 47/53 for smaller TT to 45/55 for motorhomes or V-large 5vers with residential refrig.
Once you do get "4-Corner" weight as with RVSEF you can do a simple once a year check on axle only on CAT just to be sure those extra bowling balls you started to carry haven't changed your total axle weights too much.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 06-25-2016, 06:22 PM   #22
The hitch has adjustment holes so I was able to re-bolt it and get it 2 inches higher. When I place a level on the bottom frame rail it is now just slightly nose heavy but it is much closer to being level than it was in the old position.
It now looks tail heavy when simply eye-balling it, but I suppose the body could be lower in the back.
I'm curious to know what you guys think is the right way to determine when the 5er is level. Frame rails or another way?
Btw, the reason for moving the nose higher is to help balance the weight between the front and rear axles.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 06-27-2016, 02:53 PM   #23
Head Rambler
The frame rails are the proper way to determine level. Every thing is derived from the frame (or should be).
Gotta go campin!
Old 06-27-2016, 04:50 PM   #24
Thanks for the confirmation.
I've been reading where some say to measure frame-to-ground at the front and rear of trailer instead of using a bubble level. That makes sense in case the road is not level.
Old 06-28-2016, 11:16 AM   #25
Head Rambler
That is true. If the road isn't level then you can't rely on a 'level' to know if the RV is parallel to the surface.
Of course, this only applies to towing. When camping, you want the RV Level no matter what the pad is.
Gotta go campin!
wheel
