Old 03-23-2015, 03:05 PM   #11
geotex1's Avatar
Originally Posted by OldCoot View Post
So the tire mfgrs have not changed the design since the first ones built?
According to: All About Trailer Tires | Big Brand Tire & Service
they state the following:
IMO, do not rely on a website that amounts to information that is nothing more than someone's ungraded term paper. All but one reference is several hands-removed from fact. The Carlisle reference is the only one worth any weighting and theirs is actually a pretty good one that has hung out their qualifiers for public knowledge the longest (but they also had the toughest run with bad STs). Anyway, seek out conversations with the technical folks (definitely not sales folks) and review the product literature from the manufacturers directly for yourself.
Specifically in your highlight, the first two sentences are true outside of EU-code tires. The third sentence is not fact, it's a derived opinion and you will not find it in any ST-tire manufacturers technical summaries, specs, or sales sheets. This is because it's not that simple. It's a more complex interaction of the tire construction (more shoulder than sidewall), compound, profile, and tread that equate to cornering behavior. Further, cornering behavior is not the same stress condition as a turntable maneuver that I was specifically discussing, which is actually a design consideration to a steer tire.
That said, ST tires actually have not changed substantially since their introduction in terms of structure. Certainly some tread variation. The materials definitely have changed in terms of rubber compound and also the belting (sometimes for the better, sometimes not), but not really any fundamental departure from the traditional North American ST design approach. As far as the tire manufacturers see it, there's no demand and R&D is pennies in a bucket compared to passenger vehicle tires.
In these years, I am only familiar with some numbers from one major source of ST tires for a 5 year snapshot. The number of reported failures and complaints barely register a full percentage point versus number of collective units sold. Barely 1%! No doubt in my mind reporting is a gross underestimate because the end-users don't report the failures. One way or the other, they deal with it and move on or assume they did something wrong - how can't you when you read the stipulations of the ST warranties and all the conditions in the guides put out by Carlisle and the others, and I believe now all ST tire makers cut off life at 5 years in writing. It is actually a reason why you can often get compensation from one of the manufacturers as a result of failure provided you are within that 5 year ultimate window - i.e., because they deal with so few claims it's not big dollars to them so they'll appease to move on.
The actual manufacturing and its quality control is also another element into the durability/serviceability of STs (and any tire). I've seen many argue the "built to North American standards" or "built to US specifications", but with 3-5 year design lives that's not challenging when you also follow the laundry list provided with the ST tire maintenance and warranty guides. IMO, just all means of wiggling out of more responsible designs. Further, I have put my own two feet on the floors of tire plants in several parts of the world, and I would say that you see very little difference between plants in the same socioeconomic region regardless whose name is on the shingle. Frequency of quality control checks and testing is wide, and batches from a single production lot can differ. Only takes a few degrees of off-spec temperature in the Banbury to produce an inferior compound from the finest of constituents. Then with modern tire building done in a two-phase process, the final curing stage is critical and relies on careful temperature and pressure control to aid the chemical reactions along. Slight variation, inferior compound, and contaminants (even worker sweat) greatly effect this final, critical step and failures because of this appear no different that overload/under-pressure delamination...
There's no reason that a better trailer tire cannot be designed... The EU requires a better standard to be followed, but the market is far less and there's few sizes that work with North American trailers. Manufacturers just don't see the need or demand to improve.
Alright, now okie joe, I apologize for my part in rolling your topic down the sidebar of STs!
geotex1 is offline   Reply With Quote
Old 03-23-2015, 03:27 PM   #12
thebrakeman's Avatar
After 7 seasons with a single-axle popup, we got the 261T. First time I backed it into my driveway, I was pretty impressed with myself, until I heard some screeching and looked at the tires. The entire tread looked to be shifted 2 inches sideways relative to the wheel.
From then on, I take as many times as necessary when on concrete, and never go past 45 degrees or so. On turf is different. But I still always watch the tires, to be sure they aren't shearing like that.
Turn-tabling?? No way! I don't care how well they are made, or how new is the technology. It's doing damage that just isn't necessary.
thebrakeman is online now   Reply With Quote
Old 03-23-2015, 03:30 PM   #13
The main thing is to NEVER park the trailer with the tires in a bind. Always pull forward and back a couple of times to get the tires straight.
Old 03-23-2015, 08:01 PM   #14
I just got my first 2 axle trailer and worried that my habits from my single axle are not good. There are sites that I don't know how I'd get in if I never exceeded 45 degrees. Can anyone link to a good video that demonstrates how to avoid these problems? Thanks.
tragusa3 is offline   Reply With Quote
Old 03-23-2015, 08:24 PM   #15
jriddering's Avatar
When backing my 5th wheel at home, I have a more than 90 degree turn on dirt. I have a pile of pea gravel that I will throw a bucket on ground to help let tires slide sideways. Works pretty good.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 03-23-2015, 09:04 PM   #16
The original question was about AXLES, not tires. This thread is turning into an out of control monster, IMO.
Papa GLS is offline   Reply With Quote
Old 03-23-2015, 09:09 PM   #17
Platokidd's Avatar
X2, I use sand pea gravel mix when backing in my drive. Towed with both wide track and shorter axle spacing units. The wide track axles performs very well for me on the road with no problems at all. Imo they tow much better then the normal spacing TT on the road. It may take a little more effort backing in a campsite, not a big deal if your good at backing up.
Next year is here - GO CUBS- 3 more WINS to go
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 89 nights of camping
Old 03-23-2015, 09:44 PM   #18
Great Discussion
Great discussion I started, thanks for all replies. I have been looking at a Jayco Whitehawk 27DRSL with weight of 5500# or so and only 510# tongue weight vs a Flagstaff 26RLWS with 5600# and tongue weight of 739#. One less than I would like and one more than I would like. Jayco has wide trax axle and Flagstaff conventional tandem axles.
okie joe is offline   Reply With Quote
