Old 06-20-2013, 08:21 PM   #1
Opinion on Truck
Hello:
New member. Second post.
We are renting a TT with a weight just under 6000lbs. We have a 2012 F150 Super Crew, 5.0L, 4x4, XTR. 3.73, tow package.
The dealer says I can tow the trailer with our truck. I tried a tow calculator on-line and it indicated I could not (I may have entered some numbers incorrectly)
I have done a lot of investigation on several forums, and any time there is discussion of what vehicle can two how much trailer, there are as many opinions as posters.
Any advice/opinions here?
Thanks.
hyperhad is offline   Reply With Quote
Old 06-20-2013, 08:31 PM   #2
PHS79's Avatar
6000lbs is no problem! Just make sure that you use a WD hitch.
From what I was able to find it looks like your truck is rated to tow 9300lbs, according to the 2012 Trailer Life towing guide
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 06-20-2013, 08:39 PM   #3
Steeljag's Avatar
Hyper- assuming you have a good WD hitch you should be good. The 4x4 may come in handy, but actually reduces your towing capacity.
Do you know what your payload # is? Are you hauling anything in the truck bed, i.e, generator, wood, four wheeler?
Your truck has a solid engine, good gearing, and a tow package.......don't over load the truck and you should be good to go!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 06-20-2013, 08:53 PM   #4
MOTrout's Avatar
The biggest issue with 1/2 ton pick ups is the payload rating. Look at your yellow sticker and see what it is. Figure in all the passengers and hitch weight and gear and see where you are. If you have a trailer that is 700lbs of hitch weight you may be driving two vehicles if you have a lot of gear and a big family.
MOTrout is offline   Reply With Quote
Old 06-20-2013, 08:58 PM   #5
Twisty's Avatar
Just got back from the Oregon coast.
My truck;
7200 GVWR
1520 payload
5.0 engine, 3.55 gears, 4x4
Loaded the truck with quite a bit of wood, 2 dogs, 2 people, 2 bikes, some tools...
Full cooler in the front of the trailer and "supplies" for 4 days, 2 batteries, 2 full propane tanks...
Front axle 3350
Rear axle 4000
Trailer axles WDH connected 5500
150 over GVWR
about 700 under GCWR
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-20-2013, 09:00 PM   #6
prof_fate's Avatar
That's marketing hype...Potentially you can tow 9300 lbs - if you have 1/2 tank of gas and only 150lb driver, no options on truck other than tow related ones (as in tonneu cover, running boards, etc).
Every pound you add to the truck comes off that max tow rating. It's calculated from the GCWR less truck curb weight.
So for a silverado with a tow rating of 9600lbs in 'the guide' may work out like mine - 15,500 GCWR and the truck weights 5645 so it's REALLY 9855! Then we add me, the wife, kids, bikes, the dog...and tow weight drops. Add the tongue weight of the trailer and suddenly we've exceeded the GVWR of the truck yet still have a couple of thousand pounds of tow 'capacity' available.
My expedition is 'the guide' at some big figure - then one reads the manual and four wheel drive reduces tow rating 500lbs, 17" wheel options reduces it another 500lbs...and what you think you can do you can't do.
The guide is just that - a guide, a place to start. READ YOUR MANUAL and check the stickers on your truck.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 06-20-2013, 09:29 PM   #7
So the consensus is that I need a WD hitch?
GCWR 15100
Trailer Weight 6000
Truck Curb Weight 5348
GVWR 7358
Cargo 1375
Tongue 2010
These are the numbers I can find in the door stickers, manual, the Ford site, and from the dealer. He says I can do this, no problem with our truck. He did not mention a WD hitch.
Does this seem correct, and good to go?
Old 06-20-2013, 09:32 PM   #8
bikendan's Avatar
first, where did you get the 6000lbs. number for the trailer? post the year, brand and model so we can look at the specs.
second, YES! you'll need a WDH and also sway control. a 6000lbs. trailer will be over the amount your owner's manual will require you using a WDH.
read the towing section in your owner's manual!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-20-2013, 09:33 PM   #9
MOTrout's Avatar
Look at the sticker on the hitch itself. It will tell you the limits of the hitch with and without WD hitch.
2012 F150 XLT SCab 4X4 Eco-Boost
2013 Coachmen Freedom Express 246RKS
Old 06-20-2013, 09:37 PM   #10
Yes, you definitely need a WDH with sway control to make the drive enjoyable.
Tongue 2010 ????
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
