Old 07-08-2015, 08:24 PM   #31
Originally Posted by Tonkatoy77 View Post
2011 is when the frame, suspension, and brakes improved. There was no changes in 2013.
Oops, Correct. They only change for the HDs was the wheel bolt pattern in 13.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 07-08-2015, 08:27 PM   #32
As said before, I have both engines - 2007 GMC Classic 2500HD 4x4 Duramax and 2013 Chevy G4500 with 6.0, 4.10 rears. NEITHER is noisy! Duramax is quieter going up mountains. You can have normal conversations in the cab going 70 mph on level road in either. Diesel collects water if you leave the tank cap off. Had Dodge Cummins dually in prior life and had to drain the water filter on several occasions, but have not had to drain filter on GMC during the 85000 miles I've put on it. You guys bashing the 07 Classic Durmax LBZ need to talk with folks who pull for a living. That's a highly favored engine/transmission combo. But as I said before, the 6.0 (which has variable valve timing and not to be confused with it's predecessors) with 4.10 rears pulls really good, and if you have 5k or less annual towing mileage, an excellent (would be my) choice. I stand by my mileage figures in the prior posts. Seems like there's always someone with an axe to grind.
RubberNail is offline   Reply With Quote
Old 07-08-2015, 08:33 PM   #33
mike.t's Avatar
Didn't they also change in '10 or '11? I had an '11 2500 HD and for the life of me could not find a used rim.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-08-2015, 09:22 PM   #34
When camping season is done. I drive around till the tank almost empty then put in winter fuel for us in Iowa. Then truck sits in driveway all winter till about March. I do start it up once a week and let it run to temperature, it's also plugged into a block heater on a timer. For about 4 hours. So far no issues on the fuel side. But def fluid does freeze up when it really cold outside, when that happens the def and engine light comes on, but when temp outside rises light goes out. But otherwise a very good truck
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 07-08-2015, 09:39 PM   #35
I own a 2007 Chevy Duramax Diesel with 97,500 miles on it and I have replaced a Glow Plug since I bought it new in 2007. I think 2008 and above years have a type of catylitic converter installed which reduces the horsepower by 8-10%. My DW wants me to replace the spark plugs during the 100,000 mile tune up!!!!! (:>)
saltyman is offline   Reply With Quote
Old 07-08-2015, 09:48 PM   #36
Ford Idaho's Avatar
Well if you are doing the plugs you just as well get a cap and a set of wires to go along with them.
Have you replaces the muffler bearings yet?
Old 07-08-2015, 09:53 PM   #37
Tonkatoy77's Avatar
Yes in 2011 they went to the 8x180mm
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 07-08-2015, 09:55 PM   #38
mike.t's Avatar
Ford. I think that was a smile he put in after the spark plug thing.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 07-08-2015, 09:56 PM   #39
Tonkatoy77's Avatar
You forgot the points and condenser too!!
Old 07-08-2015, 09:58 PM   #40
WOW! I can't believe ANYONE would have to ask this question! Is there any other truck out there besides a RAM w/6.7 CUMMINS and a 68RFE trans??? I should think not. The answer is simple.
gilwilliams101 is offline   Reply With Quote
truck
